61 - 73 of 73 Posts
Many Thanks. Unfortunately, many things are not as simple as they look.
They never are but if was easy everyone would be doing it lol! Keep on keeping on and you’ll get there!
600er Bandit mit 1052 ccm GSXR Motor
Discussion Starter #63
Yes, unfortunately it is. I (almost) always like the results.
148799
148802
As I said ALMOST always
148801
Discussion Starter #65
Housing repaired with 2 component glue. The rest is the new turned part.
148815
148816
148817
Here for comparison. Plastic original. Replica aluminum.
148818
148819
148820
148821
So and here with the case and plastic disc and small refinements and here with real glass
148823
148824
You could say: like new! Just nicer!
Super Moderator
You’ll need to report on how you like the wideband. I’m thinking really hard about getting one for one of my projects.
Later, Doug
Discussion Starter #67
OK I will do it. At the end of the manifold it will do its job. But each of the 4 manifolds also has a place to adjust the engine correctly.
old fart
got one of these to fit to mine, new build has exhaust port, GS exhaust will need modifying yet
Discussion Starter #69
As I said before, I don't like the modified swing arm mounting.
148891
148892
I would like a swing arm bearing that has no play. Neither radial nor axial.
So clamp the rocker in the milling machine and align it meticulously in order to mill the bearing seat to a minimum for correct bearings.
148893
Goes amazingly well. I didn't think so.
148895
3 bearings per side are planned.
148896
148897
148898
a new spacer sleeve with lubrication grooves .........
148899
148900
........ joins the old spacer sleeve that has been minimally shortened.
148901
Discussion Starter #71
My GSX-R 750 SRAD fork is by nature a bit too short for the Bandit. Therefore I had to extend it a little. From my point of view, the easiest thing to do was to extend the fork plugs.
148950
Copying is not that difficult as the plug is simple in structure.
148951
148952
148953
So quickly get 7075 aircraft aluminum ...............
148954
........................... and the project implemented.
148955
148957
Almost done !!!
148958
Discussion Starter #72
What bothered me for a long time was the insufficient space of the gas Bowden cable under the tank and the associated unfavorable relocation of the gas Bowden cable.
148959
148960
148961
I built something myself with optimal angles and the whole ball bearing.
148962
148963
For me this is the best angle and the throttle cable no longer kinks here.
148964
148966
148967
Here with a gas Bowden cable. Also do-it-yourself. Coated stainless steel cable in a Teflon cover from JAGWIRE. Actually made for braking on bicycles.
148965
61 - 73 of 73 Posts
