141 - 160 of 167 Posts
600er Bandit mit 1052 ccm GSXR Motor
Discussion Starter #141
Who knows or thinks there is another solution, please let me know. I am hard to get out of my dreams. But I don't flex or drag around the coated new frame !!!!!!
That’s some great work, I made a new upper shock mount for mine, I needed it higher, a bit hard when your frame is already coated though.
Discussion Starter #143
Yeah shit went wrong. The handlebar that you turned yourself hits the lower bracket. Must come up with something else. That's the negative! The positive I have a new one (actually an old one, because it was used)
I got a shock absorber.
149514
Makes a good figure. It is going to be !!!!
149515
Discussion Starter #144
the yellow feather is crap. Is a "***********" shock absorber. But yellow doesn't work at all. First I threw the pen into the hot paint remover. now she is naked and first sent to the powder coater. It must turn red!
149516
149517
so in the meantime I can deal with the "correct" diversion.
Discussion Starter #145
that's supposed to be called *********** shock absorber.
Discussion Starter #149
where is the problem with the word "white" and the word "power"
Discussion Starter #150
cannot be written as a word. No matter now you know what kind of shock absorber it is.
Discussion Starter #151
Experiment with the original strut. The Shock absorber that doesn't want to be named was once for the 1200 GSF.
149518
there is not much space !! it either hits the rear of the swing arm during rebound or the front of the swing arm during compression.
149519
well have enough diversions lying around. You can build the guide bones yourself.
Youd think one motherfukcer at the company in the year 2021 would have the sense to change the name. I know I wouldn't have a fuckin wp part on my bike.
Discussion Starter #155
Unfortunately, the google translator doesn't translate that correctly for me.
I read it 10 times now and don't know exactly what you want to tell me.
Sorry!!!
can you rewrite the answer differently?
Discussion Starter #156
So the nib is back from powder coating. A friendly red now adorns the nib
149563
149565
then I'll put the shock absorber back together and polish a few more parts.
Discussion Starter #157
The swing arm is with me again. She got a friendly, not so aggressive black.
149566
149567
149568
Then I can also install the new bearings here. Furthermore, the bearings have grease nipples.
Discussion Starter #158
So this time I installed needle bearings and not the original bearing cage. There are also 2 bearings on each side. GAME FREE !!!!
149569
149571
And at the front there are now 3 bearings on each side. A mixture of ball bearings (axial play) and needle bearings (radial play)
149573
149574
So now install it first !!!!!
Discussion Starter #159
I completely forgot to mention the modification of the rear brake cylinder. Chose a different return spring.
149589
I chose the one from the GSXR 1000 as the brake lever. He had the nicer shape.
149590
Discussion Starter #160
The swing arm is back in its place of work.
149591
149592
Everything is as it should be again. Storage without play. Wheel in the middle. The chain runs straight and parallel to the wheel.
149593
The swingarm looks so good, but the rim looks so shit. I have to take care of it !!
So first of all it's time to polish what it's got!
