Well, it wasn't a great night at Moto Welding School, but progress was made.
I got stuff ready for bubble testing the mini purge. I cut down the vent tubing, plugged one end, and smoothed out the ends with a file. The holes/slots in the tube increase in size from proximal to distal, which I thought would help even out the gas distribution. Found a water bottle large enough for the tube, and made a plan.
I know that water pressure (even the small amount in the bottle) is considerably more than ambient air pressure. So, I figured it might not work, or could take more argon flow pressure to get results. First plan is vertical bubble, second plan is horizontal bubble, third is smoke test. Whatever works.
Couldn't get a good pic, I guess because of the bottle shape. You can definitely see lots of bubbles at the top. I could see clearly in person.
In order to get bubbling out of the distal vent, I had to crank up the argon to 60cfh. So, the test worked, but the results suck.
For the horizontal bubble test, I dumped half the water and layed the bottle on its side. Was able to get bubbling from the distal vent at 20cfh.
My guess is that the vent tube will work okay in ambient air, using normal argon pressure. I'll purge the box for a minute or two over 20cfh before use. Will also figure out a removable cap for the distal end of the tube so I can remove it momentarily when purging to get argon past the distal vent.
I'll skip the smoke test. Was going to put smoke only into the bottle to evaluate the vents.
Bad news is, I forgot to bring the box home. I was going to draw the welding plate tonight and give the drawing to the instructor tomorrow. He said he might be able to get it made at his (other) job. Might be able to draw it tomorrow at class, but I hate to reduce my TIG time.
I think my project tomorrow will be a 1/8" aluminum cube. Did some aluminum welding tonight, but took forever to get the testing done.
