1 - 5 of 5 Posts
Ok I know there are a couple people who can machine things, can anyone make me a gauge bracket? I can send you the broken gauge so you can see the mount points and how it needs to be shaped. I can also just do pictures if thats ok and then measure for you.
KatBuilder
Does it need to be machined or can it be punched and formed. Could probably make up something stout enough in .069 aluminum...what cha got in mind?
Well Im actually going to try something else. The shop that helped me with the katana is going to make an induction ram air for the hole in the middle of the frame and mount the light setup in that, so they are also going to see about making a bracket to hold the gauges.
here is what the back looks like
Thats not mine but gives you an idea.
1 - 5 of 5 Posts
