1 - 2 of 2 Posts
Anyone of you guys replace their stock sub frame for a custom one? And also had to tuck their wires, battery, ecu, fuse box underneath the gas tank? Post of some pics of your set up.
Oiler Boilereerer...er(s)
Personally I just run split loom for my wires. Ocassionally I use those insulated on bolt holders, but usually just sip tie. Depending if you want it to look real nice, you can either run the wires through the frame tube, or use the same clamps and brake or fuel hardline bent to fit (use grommets on the openings either way)
I can't give ya any clean examples, cause it's always function first. I personally like to be able to get to the wires easily if need be so they are loomed, also it has something to do with the fact that I can't fucking leave anything alone ever and so I constantly change shit.
1 - 2 of 2 Posts
