I have a one off yoke machining job looking for a machine shop preferably in the Manchester or Cheshire area. Final dimensions to be decided but fundamentally copying a set of Hinkley Bonneville top, bottom yokes and stem. Nothing too fancy going on, stock factory type look is required. Changing from standard Triumph forks/single disc to a set of period Ceriani/Maxton forks with twin discs. Changes from stock geometry are 38mm fork tube and 200 to 205mm fork centres. Everything else as stock. I actually have two pieces of 6082T6 alloy flat bar suitable for the job but I need a machine shop recommendation for this one off job. Anyone care to make a recommendation?
Thanks, appreciated.
