Dads CB
8105 Views 119 Replies 7 Participants Last post by  Smoker
3
new owners appear to be ripping the soul from the forum, But i'm not making one myself, so lets make the most of what we got
can't complain about it and then not participate
My Dad died way back in 2007 ,he'd had this bike since about 1991, we kept it alive with GPZ900r exhaust cans, CBR900r coils etc, it's been sitting waiting on me for a long long time, so I'd like to get it done while my step mother is still here to see it
bikes already pretty stripped, font end is underway
I don't have a photo of a newspaper , because ..... fuck the newspapers and their lying agenda
Wheel Tire Bicycle frame Bicycle handlebar Bicycle tire
Motor vehicle Automotive tire Automotive design Automotive lighting Wheel
Tire Wheel Fuel tank Automotive tire Automotive fuel system
  • Love
Reactions: 5
61 - 80 of 120 Posts
2
in today's sad excuse for an update
couple of M14 stainless dome nuts and a pair of stainless spacers for under them
yes....... I should have done more .... but i have a bike to get together for my boy
Hand Finger Thumb Nail Wood
Automotive tire Vehicle brake Bicycle part Rim Motor vehicle
Reactions: 3
latest lunch time updates
got a start made on the headlight bracket, as ever it still needs plenty finishing, but chipping away at the stone
Wood Bicycle part Composite material Auto part Tool
Reactions: 5
2
I stuck the standard foot controls on and the foot peg position is spot on , so I thinks ... can I just chop the hangers.... tried it.... looks a bit like I just chopped the hangers... hmmmm ..... scribbled on them with a pen and kinda like it, I will properly draw it up and do it at work, I want it to match both sides and look proper
Tire Wheel Land vehicle Crankset Bicycle tire
Tire Wheel Crankset Bicycle tire Bicycle frame
i'm going to use them as exhaust hangers too , stick with twin cans , mimic the stock headers, but in stainless, I had considered using stock headers, but by the time I have them ceramic coated or plated it'll be cheaper to use tube, a couple of bends and pie cuts
Reactions: 1
7
The battery now sits nice, the way it's bolting in I won't have to weld the tray in place . i need to look for a replacement starter solenoid, and igniter boxes , but the reg/rec looks good. Once I have the parts i'll get more work done on the tray
Grille Automotive lighting Hood Motor vehicle Headlamp
Automotive tire Motor vehicle Bumper Automotive lighting Gas
Motor vehicle Automotive tire Bumper Automotive exterior Hood
Hood Motor vehicle Automotive tire Automotive lighting Bumper
Wood Asphalt Line Bumper Road surface
Black Rectangle Font Pattern Metal
Font Rectangle Metal Fashion accessory Circuit component
Reactions: 3
leaving this here incase i need them
4
knew I had a metal muddie in the shed, for some reason I had it in my head that it was a skinny front one.... turns out its a wide rear one
the Rad isn't perfect and it's too long, but I can work with it
Tire Wheel Automotive tire Vehicle Motor vehicle
Footwear Shoe Human body Helmet Fashion accessory
Tire Wheel Fuel tank Vehicle Automotive tire
Wheel Tire Land vehicle Vehicle Plant
Reactions: 4
i think this bike might no longer be mine.... isn't getting sold as it was my Dads..... turns out his Grandson really likes it .... seems fitting
  • Love
Reactions: 5
wait there's a baby Yan?! Do he weld yet?
Nah, stuff is all there when he wants to learn tho ....
Reactions: 3
5
lets get this moving, spent the last while helping other people
i've cut the material for the battery clamp posts, hopefully start machining them tomorrow
the m-lock is on, but I don't like the angle, so it might be off again and adjusted
m-unit is in place
reg/rec is awaiting its mount
igniter units are in hiding...... i need to build this bike before i lose anything else
Gas Rectangle Camera accessory Auto part Machine
Tire Wheel Motor vehicle Automotive tire Crankset
Motor vehicle Automotive tire Automotive exterior Tread Bumper
Wheel Tire Fuel tank Motor vehicle Automotive tire
Automotive tire Motor vehicle Tread Automotive design Rim
Reactions: 3
5
found the igniter units..... same place I found the missing m lock while sorting out the GSXR funnily enough
that's the battery clamped in, m:unit in, m:lock re-positioned, igniter units on a bracket , just need to buy a new starter solenoid now .... and join them all up of course
Typewriter Office equipment Motor vehicle Engineering Office supplies
Motor vehicle Automotive tire Automotive exterior Automotive fuel system Automotive design
Motor vehicle Vehicle Automotive exterior Gas Auto part
Automotive tire Motor vehicle Fuel tank Motorcycle Hood
Tire Automotive tire Motor vehicle Light Vehicle
Reactions: 4
2
i better make a start to the switchgear
step one - take a lump of loominum
step two - make initial profile cut
step three - clean the machine up sharpish
Wood Gas Automotive tire Bumper Flooring
Wood Grey Material property Composite material Rectangle
Reactions: 2
6
fucked about a bit more with the shape of the muddie, radius still don't match the wheel exactly, but it'll do . used welding wire to mock up mounts ( been swithering over this for ages... how to attach the front mount, went with loop over the top to match the rear ) , then found some stainless tube. might replace it with solid mild steel bar, less inclined towards cracking ?
Wheel Tire Automotive tire Vehicle brake Motor vehicle
Tire Wheel Crankset Bicycle tire Bicycle wheel
Tire Wheel Automotive tire Motor vehicle Bicycle tire
Tire Wheel Bicycle tire Automotive tire Vehicle
Tire Wheel Crankset Bicycle tire Automotive tire
i'm not using the P clips, I will be welding up proper fittings
Reactions: 4
2
today's nugget of wisdom.... check your program before running it ..... yes it has a certain aesthetic to it... but its a fuck up
Gas Wood Metal Fashion accessory Font
Wood Motor vehicle Gas Font Engineering
Reactions: 1
2
so machine was halted mid flow and a do over initiated
Gas Wood Engineering Nickel Machine
still rough , but it always is at this stage
Reactions: 4
3
all the roughing done , test fit on the bar, with the buttons
Bicycle Wheel Tire Bicycles--Equipment and supplies Crankset
Bicycle Wheel Tire Crankset Bicycle frame
Wheel Tire Automotive tire Automotive fuel system Motor vehicle
Reactions: 3
2
left hand side side underway
Hand tool Metalworking hand tool Wood Tool Gas
Wood Gas Nickel Auto part Screw
Reactions: 3
2
couple of unforced errors due to rushing too much, but it's on
Motor vehicle Automotive tire Vehicle brake Bicycle part Rim
Automotive tire Motor vehicle Automotive design Vehicle Alloy wheel
  • Love
Reactions: 5
