21 - 40 of 83 Posts
Discussion Starter · #21 ·
As the old adage goes, pride cometh before a fall, caliper looked fine until i attached it to a fork leg, the cap screw heads hit the fork leg (for some reason the XVS1100 has 8mm holes in the discs and m8 threads, instead of the normal 10mm hole)
Bit of a hunt about dug up a set of disc bolts, with the aforementioned plain 10mm dia, and heads 3mm thick instead of 8, a bit of drilling later and we're back in the game
The calipers need spaced up 10mm, so i'll then to the list
Headlight arrived today, 24hr delivery on a bank holiday .... what a time to be alive
and the 22mm bearings have been sleeved to fit the imperial holes , only one fitted as I need to make a crush tube
Tire Wheel Automotive tire Motor vehicle Vehicle brake
Wheel Tire Bicycle tire Vehicle Automotive tire
Wheel Automotive tire Bicycle part Tire Automotive design
Gear Automotive tire Automotive design Computer cooling Crankset
Automotive tire Automotive lighting Crankset Motor vehicle Vehicle brake
Automotive tire Automotive lighting Camera lens Motor vehicle Camera accessory
Discussion Starter · #22 ·
dug out the swingarm pivot tube I was going to use on the last build, before I changed plans, it's been trimmed, but still a smidge too long , and waaay too heavy , both of those will be addressed
crush tube has been turned for the rear wheel, to replace the lump of steel tube that was in there, it needs a checking too
Engineering Gas Automotive tire Composite material Machine
Discussion Starter · #23 ·
progress is slow, the pivot tube fits, i can now see about halving its weight now
turned up 4 caliper spacers, couple of the dia are a few thou tight, i'll sort that out in the morning
Household hardware Finger Nickel Thumb Gas
Motor vehicle Automotive exterior Gas Bird Automotive tire
Discussion Starter · #24 ·
caliper spacers sorted out, took 5 min this morning
then onto making the pivot tube look a little more interesting
need to spend a couple of bob now, those calipers bolts won't do... I only have two, one's too short and they're both scabby as fuck
Tire Land vehicle Bicycle tire Crankset Bicycle frame
Motor vehicle Automotive tire Gas Auto part Automotive exterior
Hand Bicycle fork Bicycle frame Bicycle part Automotive exhaust
Wheel Tire Land vehicle Crankset Bicycle
Discussion Starter · #25 ·
was going to size up for a new steering stem... then thought... I have a stem, it's perfect for this bike , in fact it's been in this bike for over 30yr, so i ground the weld off and punched it out of the stock yoke , sorted
Automotive tire Motor vehicle Automotive fuel system Vehicle brake Rim
Automotive tire Bicycle part Bicycle fork Hood Automotive exhaust
Discussion Starter · #26 ·
The tank looked to have some surface rust, no leaks, but a bit scabby, so I best tidy it up before it ends up finding religion
ahhh, too late came the cry, one holy tank
not too worry, I'll silver solder the holes, clean the rust off and possibly put some tank sealant in the seam
since the tank needs a bit of work I might as well cut a big fuck off hole in it , graft on a bit from a newer Honda
that'll need to do for right now, the pup needs a run ... laters
Musical instrument Motor vehicle Automotive tire Gas Automotive wheel system
Automotive lighting Automotive tire Hood Motor vehicle Automotive tail & brake light
Automotive lighting Motor vehicle Automotive tire Bumper Gas
Automotive parking light Wheel Tire Automotive tire Automotive lighting
Wood Road surface Asphalt Composite material Tints and shades
Discussion Starter · #27 ·
will be quite some time before I need these, but as I had to order new ones for the GSXR ( originals were donated to someone else's build) .....
started designing the swingarm, pics later
Automotive fuel system Motor vehicle Automotive tire Vehicle Automotive design
Motor vehicle Automotive tire Automotive exterior Automotive fuel system Rim
Discussion Starter · #28 ·
sprocket cover must have had 30yr of crud in it , enough to start with a steel rule, scraping it off, then a wire brush with degreasant and finally the parts washer
Wood Automotive tire Font Charcoal Rectangle
Sculpture Wood Art Safety glove Auto part
Automotive tire Bicycle part Rim Bicycle chain Automotive exterior
Bicycle part Camera accessory Automotive tire Rim Carbon
Discussion Starter · #29 ·
how to blank off the tacho drive on an old Honda motor
have a look at the stock item
load a piece of billet in the lathe
turn the bit that goes inside the engine
....... do the rest of it
Finger Household hardware Automotive tire Gas Nickel
Automotive tire Automotive wheel system Bumper Automotive exterior Gas
Wood Gas Nickel Cylinder Composite material
Hand Automotive lighting Finger Gesture Gadget
Hand Gesture Finger Household hardware Gadget
Discussion Starter · #31 ·
thought I'd best make sure the tacho plug fitted.... all good
needed caliper bolts, I like tye'tainy yum caliper bolts, nowt to do with weight, it just pleases my inner magpie
so now that the calipers are on I can get measured up for yokes, the new forks are 30mm too short and I want nice yokes not big muckle lumps of billet, so thinking short extensions
Motor vehicle Wood Auto part Tool Automotive tire
Camera lens Reflex camera Digital camera Camera accessory Auto part
Hand Finger Thumb Nail Nickel
Wheel Tire Land vehicle Vehicle Crankset
Discussion Starter · #34 ·
managed to grab a couple of hours in between workin on the back yard, left it to set and went for rum , rub down again tomorrow , then a guide coat of paint
Automotive tire Motor vehicle Automotive lighting Automotive design Wood
Tire Saw Automotive tire Automotive lighting Wheel
Discussion Starter · #35 ·
as promised guide coat added, without any rubbing i can see the side needs a good bit of work, top's getting there tho
still stuck on what to paint it, black is an obvious choice.... but its an obvious choice, same as grey, every cunt and their mother is painting everything grey just now . Needs to be classy..... time is on my side for now
Jaw Eyelash Gas Automotive design Automotive lighting
Hood Automotive lighting Vehicle Wood Grey
Hood Automotive lighting Automotive tire Vehicle Motor vehicle
Eye Automotive design Automotive tire Automotive lighting Rim
Super Moderator
we now have a more modern filler neck , tidy that up at the same time as the filled holes
Hey Yan,
I’ve got a Kz tank here sitting that I’ve been trying to do the same thing to. I got stuck on how to get the vent tube installed through the bottom of the tank. The filler I have still has the factory vent tube attached. Any suggestions?
Later, Doug
Discussion Starter · #37 ·
I've never bothered with the drain tube, I did consider trying to get a position for the tube, drilling a hole in the bottom of the tank and solder it.... then I decided nah , never needed one before, why go drilling holes in the bottom of the tank . I just don't overfill the tank and make sure it has a good seal. For venting you could fit a one way vent to the tank it's self (my big build has one) or a lot of caps are vented
Discussion Starter · #38 ·
made a start on the sprocket carrier , been busy as fuck, done next to fuck all on this bike
Automotive tire Wheel Nickel Rim Bicycle part
If you're going for classy...what about a nice dark royal blue or an equally dark maroon??
21 - 40 of 83 Posts
