1 - 12 of 12 Posts
The Wizard
I have a 1996 GSXR 750 SRAD and I just did a mild cleaning on my carbs. I didn't take anything out, just took off the bowls and cleaned it all with carb cleaner. When the bowls where off I didnt see any varnish, debris or sediment. Looked good to me.
However, I did notice that the air box was not tightened on and the clamps for the carbs where loose also. I think this may have been my high idle issue.
Anyway, I made a short video to see if anyone could let me know if my bike sounds good or not. I had already started it and the temp was at about 75 c (that's 167 f for you Americans).
The short Yoshi can was already on it when I got the bike and don't know if it was or needed to be jetted for it.
Here is the link to the video: http://youtu.be/pmTqHHIrTjk
I am not able to take it for a drive because I have my learners license and I need a supervisor in order to ride.
Any feed back is much appreciated as I have a road test in 8 days and I need it to be in decent running condition.
You guys follow laws in the UK? Take that bitch for a quick rip and if it stumbles when you take off then the carbs and airbox are causing a vacuum leak
Have a friend ride it or trailer it to a private lot where you can "practice" and see if it stumbles below 4-5k rpms it could be a vacuum leak as I said before or your jetting could not be correct for the pipe but I would guess vacuum leak ( I haven't watched the vid just going off your post) everything must be tightly fastened and sealed other wise it will give you a shitty idle and a low rpm stumble
Bitches love Fighters
the srads are definitely finicky. especially the carbed ones. couldnt hurt to take the carbs apart and actually clean them right
The Wizard
The reason I haven't done a complete tear down is because I have my road test in 7 days and I haven't taken apart street bike carbs before. I don't want to chance it before my test. After my test I'll be getting into them more or take it to a shop.
1 - 12 of 12 Posts
