1 - 11 of 11 Posts
clean fight
OK. im not sure about the rules of this section, but i wanted to show yall this thing im working on- maybe some advice to make it meaner .
started last week, feb 20sumthing- with :
- a pair of hallogen "off road sport lamps" for atv i guess. not dot legal but super bright
&17$ new at the auto parts shop
- a crashed cbr rr nose of fleabay 10$
- an old face-shield for grinding
- aluminum chanel stock cut into little brackets, pop-rivets
- the alum bracket that used to hold the "no parking" sign in front of my house .
clean fight
so I chopped the upper part of the cowl where it holds the upper part of windscreen,
and i used those 2 pieces (after a bit of reshaping w dremel and beltsander) as the lower side portions.
i needed brackets that come off the front curve and come around in an angle to point to the clamps that im gonna make on the fork. so i cut up the fiberglass mold id made for my carbon ft fender project- it had just the right curve and angles to match the 2 pieces i patched onto the bottom of the nose.
i heated the bottom area up and bent the stock nose a bit so the lines would flow together and not have the jagged bracket clip thing showing anymore...
put a very thin coat of black on too.
still needs lots o sanding on the crude glasswork. the scraps i used were from the outside of a mold - it wasnt intended to be a part when i made it but hey. waste not...
4th picture is the new carbon screen after trimming to size. still needs some polish and topcoat
clean fight
LOOKING AT THE THING FRONT ON TODAY I REALIZED JUST HOW CROOKID I MADE IT-
BACK OVER THE STOVE FOR SOME PLASTIC MELTING MASH AROUND!
SEEMS MOSTLY STRAIGHT ENUF NOW, BUT I HAVE TO REDO A BIT OF GLASSWORK AT THE JOIN ON EA SIDE OF THE NOSE-TIP.
BUT I WAS THINKIN-
YA REALLY ONLY LOOKIN AT IT FROM ONE SIDE ER THE OTHER RIGHT?
WHOOS TA KNOW?
didnt see i was typin caps till just now. thats how bad a typer i am. staring at the keyboard!
actually im joking- i got it evened out fine- i guess it had gotten nudged while the epoxy was curing or something. and i dint notice till now- good thing i like doing composite work or id be pretty frustrated now.
but this is what we do right- mess with our bikes untill they turn out how we want em[
thing is i dont really even know how i want it untill ive done some messing w it- so theres alot more intermediate steps than some hobbies.
clean fight
so i did some more work last night - just patching up the seam where i put the side panels on to the nose- 2 more layers of thin fiberglass and a buncha epoxy to cover some inconsistancies. give me some body to sand down and smooth..
and i halfassed the mixing. put way too mush hardner agent . its still goo. ive got to get it back off and try again. acetone rags and wirebrush. haha!
but other than that its all good.
exept where i spattered mint green paint from another job on the bodies of the lights, the good thing about black tho is its easy to touch-up and colour match!!
1 - 11 of 11 Posts
