My KLR650 is giving me trouble...
My bike has no airbox, I removed it and replaced it with a standard uni pod air filter. It worked fine with the stock carb settings and stock pipe.
I bought a new exhaust and was told i needed a jet kit because of the increased airflow. Dynojet suggested stage 2 because I dont use the airbox.
So I installed a stage 2 Dyno jet Kit into my Keihin CVK 40, which included drilling out the vacuum hole and then installing a different main jet and needle.
I did everything to spec and when I tested out the bike on the streets it worked fine.
This morning I took it out on its maiden voyage on the freeway and about 10 minutes into the ride at the top of 5th it started to bog down? where it kept instantly losing and gaining power as if it was running out of gas (i put a fresh tank in this morning).
So what is going on here? what do i need to adjust? this bike is a big learning process and is there a way to test out if the bike will run at higher rpms that doesn't involve me being on the freeway, it was fucking scary hahaha.
thanks,
-Z
thanks,
-Z
