1 - 6 of 6 Posts
I agree, I have some chinese levers which have held up fine, but not sure I'd trust a master.
The only clue I found was it says "fitment for 125 to 400cc bikes"...which might suggest the master is only powerful enough for a single caliper, on a smallish bike.
The only thing I can say is every Chinese knock-off motorcycle I've ridden universally has terrible brakes.
Fight it till it's right
I wouldn't touch it. They tend to be poorly made so the bore isn't smooth and rips seals, and/or the seals are made substandard and the rubber goes hard. Either way you get a leak and no brake pressure.
Also the note about 125cc > 400cc suggests it's probably 11mm or at best 1/2" - enough to power a small single caliper or two small / one larger caliper. It won't power a dual brake setup as found on most modern machines.
1 - 6 of 6 Posts
