cleaned up and examined the TL swing arm, has been run with a very loose chain and damaged chain runner rubber,* chain has made contact with the support and spindle/bearing housing!! bike has been decked at some point in its life and got gravel rash to support on one side too.
should be able to get the damage welded and cleaned up.
found a set of crash protectors/paddock stand lifters, also dug out the Yoshi chain adjuster blocks i had. GSX1400 wheel spindle was used just for pic, but i have
a TL wheel spindle on its way.*
measured swing arm space in frame, 22.5cm, swing arm at spindle end = 23cm, so not going to be any problem getting the two bits to mate up
measured swing arms between spindles EFE = 22.5in, TL = 20.5in so not as big a difference as i first thought.
