561 - 577 of 577 Posts
old fart
Discussion Starter · #564 ·
**** finishing off the last bit of welding for me, left lots of ally bits for anodising with him to collect next week hopefully. Frame in for powder soon.
old fart
Discussion Starter · #566 ·
booked in at the powder coaters, dropping off sometime this morning, all the ally bits for anodising have been delivered this morning,
should have back by end of week all being well,
old fart
Discussion Starter · #567 ·
well good day in all regards, took my GS and Avrils little KTM Duke 125 for MOT, what a blast it is trying to keep up corner speed on a little bike! so its not at a stand still when you exit on to the next straight
O.o
both passed, GS with front tyre and "noisy" exhaust observations
:P
then got a call from RNR Powder coaters, frame and bits ready for collection, so quick drive over to West Tanfield to collect said item.
looks like i have some work to do over the bank holiday now
:banana:
old fart
Discussion Starter · #569 ·
just for you Sol I started to get the itch to try all the engine mounting/swing arm spindle/ shock mounting bolts for fitment,
had to remove a small amount of coating, but didnt take long, then thought as the bolts fit i might as well try the motor in,
got some left over flooring underlay, cut it down and used it as frame protection. motor in
then bolted it all in place with the mounting brackets
old fart
Discussion Starter · #573 ·
Got a bit stuck with the re build over the weekend, as i had lost one of the block locating pegs! looked high and low, but never found it,
managed to do a fit of the GSXR K9+ clutch with billet basket, just need to sort out the centre nut and all will be good.
went down to see **** at Red6 to collect a peg and pick up my bits hot from the anodizers, give me a lot more to be going on with
new metal plaque arrived for man cave wall
old fart
Discussion Starter · #575 ·
now i have most of the bits back from anodising, I was able to get the swing arm end caps fitted and clean up a small amount of coating from the mounting points on the frame to get the arm in.
fits sweet, i will fit the rest of the arm hardware later, that has also been away for anodising. still waiting on the wheel spacers to come back, so test fit of rear wheel will have to wait till then.
