1 - 3 of 3 Posts
I am hoping to replace the headlight harness for 2008 Ninja 650r with one for a standard H4 connector. I think these ( http://www.cycleterminal.com/headlight-kits.html ) would work but I am not sure whether I should get "ring terminal", "fuse box connector" or "sealed fuse box connector" option. Any help for a noob? I would rather not trust my headlight to my DIY abilities. Thanks.
Not 100% sure, but from what I gather from reading your link:
Ring terminals with removable fuse holder: This would be like a sound system wire in a car, coming off the positive post of the battery with an in-line fuse.
3 circuit fuse box connector: I believe this would go into an open spot in your fuse box, so this option would look much cleaner and closer to how they would install it at the factory.
3 circuit sealed fuse box connector: Same as the other 3 circuit fuse box connector, but with a weather-pac connector (Not sure on this one, it'd be nice if they had pics of these pieces on that site.)
I would go with either fuse box option. It is a much more professional way to do this. Any time you add a new circuit to a vehicle, be it car, motorcycle, atv, etc., you should always try to find an empty spot on the fusebox. Hope this helps.
The Hell You Say!!
You should be able to find some help around here. Post up an intro thread and tell us a little about you and your bike. Its almost mandatory...then start a build thread if your gonna do some custom work.
1 - 3 of 3 Posts
