1 - 9 of 9 Posts
Discussion Starter #1
ENTER HERE FOR THE July FIGHTER OF THE MONTH CONTEST!
Entry deadline is the 21st of July
YOU MUST HAVE 50 OR MORE POSTS TO ENTER!!!
NO POSTS OTHER THAN ENTRIES! ALL OTHER POSTS WILL BE DELETED!
All Entries MUST Include:
  • A streetfighter you own
  • 4-8 pictures of the bike
  • List of modifications you have done
If you dont meet the requirements, your post will be deleted.
Winners will receive:
A set of Driven Racing Skull Gel Grips from Moto-Madness.com
In addition, your bike will be featured on the home page of our site, and will be placed in the FOTM Gallery to memorialize your win forever!
You will also receive a "forum award" that shows up under your posts and on your profile on the site!
So... LETS SEE THEM FIGHTERS!
97 Suzuki Bandit 600
93 GSXR 750 Forks built by FCR
91 GSXR 750 Rear Shock built by FCR
LSL Top Clamp
Powder coated B12 wheels and swingarm
Sprocket Specialists Rear Sprocket
Galfer SS Brake Lines
Tokico 6 Piston Calipers w/ EBC HH pads
Acewell Digital Speedo
Holeshot Header
Holeshot Stage 1
D&D Exhaust
Solo Seat
Grab Rail Removal
Belly Pan
XB12 Headlight & Flyscreen
i will forever be useless
suspension:
05/06 636 forks, triples, radial mount calipers and radial mount master cylinder
05/06 636 rear swing arm, rear shock & linkage w/ adjustable links, tokico 6 pot rear caliper
09 636 clip ons
bodywork:
yamaha mt03 headlight
05/06 636 front fender
cbr 1krr tail
undertail with jap. auto stickers
led tail light
solo seat cowl
one off seat pan w/ shaved zx6r foam
one off copper color w/ pearl and metal flake paint mix
engine:
reangled exhaust
yoshimura titanium exhaust cut down
k&n air filter
painted side covers
misc.
no switches on bars, moved headlight switch and car style ignition to subframe,
03/04 636 gauge swap
shaved all casting seams by hand
bedliner coating on frame
shaved ram air tubes
rim stripe
cut up reangled subframe plated for for smooth look and strength
Hooligan Streetfighter
And here we go again, except with different pics!!
2005 Suzuki Hayabusa
Honda Headlight
PIAA H6M bulbs
Custom mounting bracket
Acewell Guage
05 Yammie upper fork legs (not pictured)
03/04 GSXR 1000 Lower legs w/radial caliper mounts (not Pictured)
03/04 GSXR 1000 Radial Calipers
Custom Caliper Spacers
02 GSXR 750 front wheel
Racetech springs and gold valves
HEL Stainless steel brake lines all around
HEL SS Braided clutch line
Bandit risers
Renthal bars
04 CBR 1000 RR clutch and brake Master Cylinders
Mini resi's
Custom Coolant reservior
Big Bike Air intake covers
Boz Bros B2 Exhaust
PCIII w/boz bros B2 map
custom wiring harnes/battery box under the fuel tank
Relocated ignition switch to rear shock bolt access hole in frame
One off subframe
ZX6R seat unit
Clear Alternatives integrated tail/turn/stop brake light
Speed King Rear Sets
Custom made coolant hard lines
Polishing by me
Paint by me
Anodized nuts and bolts everywhere.
Featured in Streetfighters Magazine issue 198 this month!!
captain fiberglass
well i guess i'll enter mine while i still have it:
1997 yamaha fzr 600
-airtech fzr-r1 conversion tail
-acerbis led vision headlight
-gas tank cover and tail modified with louvers
-acewell digital speedometer
-frame/swingarm/wheels/rotor centers/calipers all painted black
-led taillight and brake lights
-pearl metailic blue paint done by Woody's street rods
-cleaned/ shortened wiring
-exhaust slipon made by Meatpopsicle
-custom overflow catch tank
im sure theres other things that im forgetting...
Operation Sketchy At Best
1994 gsxr 750
F it ill throw my hat in. My bike came in peices and firing on 3 cylinders. Sold stock plastics and cluster back to the seller. As i got her.
Thanks to : Fathead, streetfighterklz, my buddy danny, and prolly some other folks :)
after some time
[URL="
[/URL]
stripped plastics and tank to bare metal/plastic
body worked the tank, lotsa dents
bought about 50+ little bolts and screws from a local hardware store
veypor gauges (still figuring out all the functions)
made a speedo bracket from 10 g steel floating around the shop
chain gaurd from fathead
normal sized sprocket and chain
homemade o-ring chain press (probobly dangerous)
aztec 8 lights (spoda be black) but whatever
polished frame
chopped up front fairing brackets to make a new stabilizer mount
chopped and riveted yosh pipe
bar end mirrors
matching frame spools to forks and wheels
same with oil cap
new shitty grips
faux carbon fiber tank pad
faux carbon levers
rewired the entire bike...fun
new lights bulbs, brackets on rear
50 foot paint job
plus makin odds and ends from different bikes fit.
would have more pics but for the life of me i cant find my camera.
I'm a lover AND a Fighter
Well, I'll try it again, boys...
1998 Honda VTR 1000F Super Hawk (Super Devil)
Hand polished frame and swingarm
Black powdercoated rearsets, passenger pegs, upper triple tree, fork bases, wheels, clip-ons
Devil mask from European Street Fighter
'Hell' front fender and 2-up tail section from European Street Fighter
Chopped exhaust (straight pipe dumps behind right rearset/under swingarm
Rizoma license plate bracket
Venom energy drink coolant catch can
Single mount radiator
Modified subframe
i'm on holiday from work , torrential rain , so i'll enter this again . good to keep the numbers up
this is it when i bought it
and this is it now
and it was built strictly for using ,
parked up on the isle of man
modifications
gsxr front wheel , brakes , bottom yoke and muddie
K3 gixxer clip ons
bft top yoke
radial master cylinder, bft res pot
modified predator mask
vapour speedo
stoopid headlight
led tail light
1995 frame
919 blade motor
stainless exhaust system , wrapped
hardcore fighters belly pan
newer curved rad
hardcore fighters seat unit
seat pad knocked up in 30 min
R1 rear wheel
bodywork carbon wrapped
rear bft res pot
shock from newer model
second gear on the way out , so have to ride hard or use first then 3rd
race tyres from a NW200 bike , get them hot and they stick like velcro
modified airbox(needs done again tho )
and shock of all shocks , it now has an mot , got my dates mixed up so it went without one for a while
never a show winner , thrown together in 3 weeks with a minimal budget , gets attention tho :party-smiley:
TWIN HITTER
i throw a late entry into the ring..
the bike i built for my wife.
the spec list:
JULY 2009 SUZUKI SFV650 GLADIUS
FRONT END:
07 GSXR 750 FORKS
07 GSXR 750 WHEEL
07 GSXR 750 BRAKE ROTORS
06 GSXR 1000 LOWER TRIPLE
09 GLADIUS STEERING STEM
ABM BILLET K6 GSXR 1000 TOP TRIPLE
07 GSXR 1000 FRONT GUARD
08 GSXR 1000 CALIPERS
08 GSXR 1000 MASTER CYLINDER
PAZZO LEAVERS
AFTERMARKET MIRRORS
ABM SUPERBIKE BARS
OBERON BILLET STAINLESS STEEL BAR ENDS
BILLET BRAKE FLUID RESERVOIR
ERMAX SCREEN KIT> INSIDE BLACKED OUT TO GIVE LOOK OF A BIKINI FAIRING/SCREEN
PINK RIM STICKERS
HID BI-XENON HEADLIGHT CONVERSION
CUSTOM HEL BRAIDED LINES (FULL 2 LINE KIT)
CUSTOM MADE BY ME:
IGNITION BARREL SPACERS
TOP TRIPLE SPACERS AND SLEEVE
BILLET PRELOAD ADJUSTERS
ONE OFF BRACKET TO HOLD GAUGES AND HEADLIGHT
REAR END:
08 GSXR 600 REAR SHOCK
06 ZX6R SWINGARM
07 GSXR 600 REAR WHEEL
BILLET SWINGARM SPOOLS
09 GLADIUS SUSPENSION LEVER
09 GLADIUS SWINGARM PIVOT TUBE
07 ZX6R REAR CALIPER
PINK RIM STICKERS
K6 GSXR 1000 MASTER CYLINDER
K7 GSXR 600 VORTEX HARD ANODIZED 46 TOOTH ALLOY REAR SPROCKET
CUSTOM MADE BY ME:
SUSPENSION LINKAGE SPACERS
DOGBONES
REAR WHEEL SPACERS*
CUSH DRIVE SPIGOT*
BEARING SPACER FOR REAR WHEEL*
ZX6R WHEEL BEARINGS FITTED TO GSXR 600 WHEEL*
SWINGARM COVER PLATE
SPACER AND BUSH FOR SWINGARM PIVOT
CHAIN GUARD W/MESH INSERTS
(*DENOTES MODS NEEDED TO MAKE WHEEL WORK ON SMALLER ZX6R AXLE)
HIDDEN REMOTE RESERVOIR (FROM 97 TL1000S) AND BRACKET
BIKE:
SIDE COVERS PAINTED GLOSS BLACK
ERMAX BELLY PAN
ERMAX SOLO COWL
PINK BUTTERFLY TANK PROTECTOR
K6 GSXR 1000 REARSETS
ERMAX FENDER ELIMINATOR KIT
CUSTOM MADE BY ME:
PINK MESH INSERTS ON BELLY PAN AND SIDE COVERS
REARSET ADAPTOR PLATES
HEELGUARDS INCORPORATING EXHAUST HANGER BRACKET.
FULL REAR HEADER AND CAT ELIMINATION PIPE
12MM BILLET ALLOY TANK RISERS
RADIATOR GUARD WITH MESH INSERT
build thread can be found here...
http://www.customfighters.com/forums...ad.php?t=26203
cheers.joe.
1 - 9 of 9 Posts
