1 - 9 of 9 Posts
ENTER HERE FOR THE MARCH FIGHTER OF THE MONTH CONTEST!
Entry deadline is the 21st of March
YOU MUST HAVE 50 OR MORE POSTS TO ENTER!!!
NO POSTS OTHER THAN ENTRIES! ALL OTHER POSTS WILL BE DELETED!
All Entries MUST Include:
  • A streetfighter you own
  • 4-8 pictures of the bike
  • List of modifications you have done
If you dont meet the requirements, your post will be deleted.
Winners will be featured on the home page of our site, and will be placed in the FOTM Gallery to memorialize your win forever!
You will also receive a "forum award" that shows up under your posts and on your profile on the site!
So... LETS SEE THEM FIGHTERS!
*I'll move this thread to the appropriate forum once its created. ;)
Eh I'll throw mine into the ring
from my buildoff entry
I bought my 1995 yzf600r August of 2009 and immediately began tearing it down. I've always liked the fighter look but never decided to go for it on my previous bikes.
It arrived at its current state after a winter of purchasing parts and a part of spring getting it all together
Mods/Maintenance:
Veypor Gauge
Rear Subframe Removed
NRC covers
Vortex racing clip ons
vortex racing gas cap and oil cap
New Oem brake and clutch levers
D3 grips
Oem clutch and throttle cable
Oem thottle sleeve
Dual Oval Headlight
CRG bar end mirror
swingarm plate mount
sliders
Ducati monster taillight
-1 in the front with new chain and rear sprocket
new hardware everywhere
new gaskets everywhere
new fluids everywhere
factory pro stage 3 jet kit
K&N Ind. Pods
cut down yoshi pipe
wrapped header
front and rear HH pads
front and rear SS braided brake lines
new battery. sheetmetal undertail
probably some more things i cant remember
annnn
future mods
Carbon fiber front fender and tank
Front Brake Mst Cyl Purchased
shorty pazzo levers
new tires
up two or three in the rear sprocket
clutch Purchased
Shift Kit Purchased
ignition advance Purchased
front and rear wave rotors
hot pink or gold powdercoated rims
powdercoat frame and swingarm
Maybe a new headlight assembly (at least HIDs in the one i have now)
Complete engine rebuild with more aggressive cams
Head rebuild port and polish with stiffer springs
VFR 750 Swingarm Purchased
Attack Performance Rearsets
Clear up tail section (cut subframe possibly)
MOTY battery
Relocate ignition
Belly pan
heatshrink and hide all wiring possible
Exhaust..reroute? brand new D&D system..not sure at this point
might as well add mine :D
i got this in November 2010 and have just finished it,
mods are
cbr 600 front calipers,
braided lines,
drilled top yoke,
risers with 30mm extenders welded on,
polished top yoke and risers,
renthal bars,
stubby levers,
aftermarket headlight,
digi speedo,
polished engine casings,
painted rocker cover,
new spark plugs, filter and oil,
custom wiring loom,
polished breather and fuel cap rim,
custom made heal plates,
custom made like pipe,
painted wheels,
custom made undertray,
carbon exhaust strap,
stubby carbon can company can,
re-jetted,
braided hose master cylinder,
custom radiator overflow tank,
modified subframe,
Kawasaki z900 seat unit,
led stop and tail light,
mods to do
full stainless bolt set,
custom wheel nuts,
billet front master cylinder,
and what ever my little mind comes up with lol,
slow month eh, here one to make up the numbers , still gorrit
i bought this
then , fitted a gixer front end
made a top yoke
fitted little lights
set of clip ons
modified a predator mask
newer model rad
slightly bigger motor
stainless pipes (now with a carbon can)
newer model shock
hardcore fighters seat unit
hardcore fighters belly pan
wrapped the headers
R1 rear wheel
vapour speedo
billet gas cap
radial master cylinder
alloy seat plate
covered seat plate for long haul trips
bar end mirror
bodywork carbon wrapped
billet fluid resevoirs
took it to the iom tt twice , ride it to work , proper all round fighter , no show pony
streetfighter
heres she goes
redone and better than ever
new one off tail section
z750 intergrated taillight
custom subframe
hidden battery and wire harness
custom metal work on tank to hide the airbox oppening
custom underbody m4 exhaust
dirtbike footpegs
new custom risers and new flanders bars
reworked triples by FOH
koso gauges
revised headlight mask
fork tube covers with blinkers inlaid
duc front fender
vfr800 sssa
msw car 17x7 rim
crg shorty levers
conrtol wires hidden in triple
driven skully grips
motocyco knuckle heel guards
moved key location
NASTY NEW PAINT
and probaaably some other trick shit
Custom Paint
My Fighter Enter
My Kawasaki zx6r b1h 04 stunt ready
Modifications :
custom paint job airbrush done by stuntair.com "me" :)
steel cage and tail bar
brembo handbrake
ez pull clutch
dented tank
fan mod
clean air mod
side stand mod
rad braced
60 tooth sprocket 520 gold chain
solo seat hole cut and reinforced
front and rear pegs changed
home made custom painted chain guard "shark fin"
Um Mods:
GSXR 1100 tubes & triples
GSXR 750 front wheel
GSXR 1100 rotors painted
Custom dual wave headlights with bracket
LED front blinkers
LSL bars
Driven Skull Grips
stainless front lines
bar end mirrors
Rattled custom black metallic paint
custom wiring harness with deleted key
Katana 750 motor and carbs
Custom SubFrame
Stainless Mesh battery box
LED rear brake and turn signals
D&D exhaust with chopped mid and can
Hyabusa rear-sets
Rear resi delete kit
That's it for now
Check the video for the full 180*
I don't even know if I'm allowed in the contest?? I wouldn't normally enter my bike, but was going to because there were no entries...now there are, but I still want to because it's not going to look like this for too much longer, and thought i'd at least throw it in the ring.
2000 CBR 929.
Body Parts:
600RR tailsection modified to a 1 piece
GSXR 1K front fender
954 RR rear hugger
Modified 929 gas tank (air intake holes frenched out)
One Off FOH headlight unit
Modified 929 belly pan
CUstom paint by Full Of Hate Cycle Fab
Bits:
Rare Grand Dragon Racing rearsets (thanks chinasteve)
Koso RX1n Gauges
Easton super-fat fat bars and clamps
ASV shorty levers
FOH fork tube covers
FLINT custom triple clamps
Braking wave rotors (front)
Stainless brake lines all around
Supertrapp modified underbody exhaust
CRG lanesplitter mirror
what the hell am i forgetting....something I'm sure. oh well.
pics.
self portraits that im proud of:
1 - 9 of 9 Posts
