1 - 3 of 3 Posts
Quackenbush Qustom
im trying to figure out a tach solution on the cheap cuz the whole bike was done budget think i barley broke 1000$ so far. im wondering if a stock xs1100 tach would be an easy solution any input would be greatly appreciated.
Senior Member
Aren't the XS tachs cable operated? Won't work on an FJ if it is.
Any 4 cylinder electric tacho should work. You might need to run a resistor in-line if the needle is jumpy.
Quackenbush Qustom
the xs ones i saw on googe images had a multi wire harness plug on it. but i found my stock doash an pulled the tach out now i need to build some kind of pod for it. thanks for your replay
1 - 3 of 3 Posts
