hey guys.
this is gonna act as a place holder as I gather parts and information for my build. I will update as I get parts and draw out the concept. this bike will be my first attempt at frame fabrication. the original name for this build was gonna be Jack the Ripper, not sure if I'm gonna stick with it or not
synopsis:
the aim is to build a bike that will be tailored to me and me alone. it will be a purpose built bike that is made to shred twisty back roads. maybe I will take it to the track someday. this bike will be functional first and foremost. if it turns out to be ugly, well then so be it.
geometry:
the geometry will be rather agressive. these are preliminary numbers, that is why I have given a range. once I setup my jig I will decide on what they will be exactly
rake: 21-22 degrees
trail: 3.25"-3.5"
wheelbase: 52"-53"
offset: 1.2"
components:
I will be fabricating many of the components as one off pieces. the pieces I don not fabricate myself will most likely be modified by me.
Frame: big tube 4130 aircarft tube or box section. I got it narrowed down to two concepts.
Motor: most likely it will be an RC51 plant, but we will see about that next week. also looking at a rotax v990 (aprilia rsv1000)
Front forks: 01 gsxr750. revalved and resprung eventually
Rear suspension: undecided, open to suggestions
triples: made by me. woot. they're gonna be pretty neat
wheels: custom cut from aluminum blanks by me
front brakes: dual perimeter setup designed and fabricated by me, most likely with a radial master
rear brakes: possibly a single perimeter rotor? not sure
calipers: most likely I will be using modified buell ZTLs, but I am also looking at machining my own billet calipers
Tank and tail: custom made by me. lookin into making a fiberglass setup. (if I can get around that pesky ethanol eating the resin thing)
things I need before I actually get started
rear suspension. I have a fox shocks double clicker kickin around. I haven't decided if I'm gonna try and set that up for this build or just go with a newer shock from a late model bike and respring it? it might be cheaper to get something off ebay.
swingarm: still not sure if I want to go with an rc swingarm with the rc motor.it does have the pivot on the engine case, so it might be the easiest way..... but hell, what part of this build is easy? might build a tubular swinger
the biggest part I need is a titled neck. I really prefer a steel one though. so that kinda cuts down on my options
a garage. lol. well actually I'm just collecting parts right now. once everything is collected I will probably rent a garage and build the bike as fast as possible.
I will be updating this thread with my rough concept drawings soon enough.
and to all you haters out there NO, I am not building my version of a GC-1000 or a hack built buell1125r. the concept and vision for this bike was in my notebook and in my head long before I had ever even heard of either of those bikes.
progress is gonna be slow until I have everything in place and ready. then I hope it will move pretty fast
what do you guys think?
synopsis:
geometry:
rake: 21-22 degrees
trail: 3.25"-3.5"
wheelbase: 52"-53"
offset: 1.2"
components:
