1 - 19 of 19 Posts
The Hell You Say!!
Not too sure if this is in the right place so please move it if it isn't. I busted a fork seal today and need to replace it. The seals are only $10 but the drivers range from $40-$50 and I don't have that kinda cash right now. I was wondering if anyone would be willing to let me borrow one. I understand that shipping could cost just as much and if its going to I will just buy one, but I'm trying to avoid it. Any help would be greatly appreciated!! The fork is off of a 97 zx9r which is 41mm IIRC.
i cant fart
I have the tusk adjustable driver. I'd be more than happy to send it to u to borrow but like u said shipping there and back will just be about the cost. It was like 34$. But if u want, I'll get a shipping quote tomorrow and send it out asap.
Super Moderator
I have a 41mm seal driver I used on my Gsxr USD's. Nothing fancy just two weighted halves. Let me know if DrJ can't help you out.
Later, Doug
The Hell You Say!!
I'm going to order the seals today and hopefully have them this weekend. I've got drill on Saturday and hunting season starts this weekend so I will have to really try to find some time to get it fixed
I've done about 10 sets of fork seals in my life and I always used the old fork seal. Just cut off about 1-2 mm from the circumference of the old one, turn it upside down and use a rubber mallet. Probably not as fast as the actual driver but it works.
sickboy
I find the zx9r provides a dangerously fun and bouncy ride when the fork seals are blown. I say leave it :thumbsup:
Here to F stuff up
There's another option similar to PVC. I used exhaust tubing from oreillys and just wrapped the end in electrical tape to protect the seal when I did the forks on my f2. Worked like a charm, and its cheap. Or at least for me since I work there.
The Hell You Say!!
I can try that to. The pvc option sounds like the easiest. I'll know pretty quickly on Sunday what works best. I also have to figure out how much oil these take. taking them apart looks fairly simple. Looks like I take the fork cap off then remove the l lower and I should be able to get the seal out. Right?
G
The problem with using a piece of pvc pipe is it can cut into or mis-shape the new seal so as mentioned above i use the old seal to protect the new one, use the old seal the right way up & its easy to get out again if it gets stuck which does not happen often
Ive been doing it this way for 30 + years & not had a problem yet thats not related to bodges by the previous owners
The Hell You Say!!
Thanks for all the help guys. I got them changed today. Wound up using the old seal to drive the new one in. Wasn't too hard once I figured out how to separate the fork tubes
1 - 19 of 19 Posts
