I finally got some time to work on the Kawi today. I went around the bike spraying all the bolts with WD40, removed the rear plastics, took out the carb rack and sprayed it down with choke cleaner, put in some fresh oil, installed the filter pods, and hooked up my Honda's battery to the bike.
After figuring out that this is one of those bikes that needs to have the clutch pulled in to turn on , I not only got it to turn over on the first try - no gas yet - but it actually fired up for a second. Got fuel going to it after that, but I couldn't seem to get it to start again. Checked for spark, and it had a very weak one. Checked for fuel by removing a drain screw from one of the carb float bowls, and had clean gas come out.
I remember that my old Ninja EX500 was very particular about its plugs, and one time would not turn on until I changed them out. I thought of this after I got home (used a new plug in the #4 cylinder wire to check for spark, instead of removing one from the motor), so I might go back tomorrow to pull one out. I really need to get a voltage tester, a service manual - can't find one on the Internet, except in German - and some hoses to redo the vacuum lines for the carbs.
I'm pretty happy that I did hear it run, even if I killed my battery trying a few different things, lol. I had a charger handy, so that wasn't an issue, but now that I heard the engine turn over, I'll get the bike her own battery.
Not much else gonna happen till I get my refund money, so stay tuned...
(The bottle of Joy was serving as a gas tank, since I realized that I'm missing a couple of lines for the petcock.)
