1 - 20 of 24 Posts
I'm swapping a zx7 non-radial set of forks onto my GPz. I've got forks and triples but no brakes. I'm looking for zx7 or equivalent (zx6/7/9, busa etc) calipers, decent lines and master.
Considering I'm upgrading from '83 technology and buying on a house funds are low and anything more modern will be a huge improvement over stock.
Super Moderator
Tusch,
What year are your Zx7 forks from? They changed caliper mounting distance in the mid-90's. They either 65mm (earlier) or 90mm (later).
Later, Doug
Reactions: ROBBO
Also, altitude pics would be great. I'm told the nissins are supposed to be a bit of an upgrade for the zx7s but like I said anything will be an upgrade over the 30 year old GPz's
Super Moderator
I am 90% sure they came off a '96 hopefully the difference didn't come between 96-97 because its one of those two years. Haha
So street, are yours the 6 pot tokicos?
The change came in '96. 89-95 are 65mm and 96-03 were 90mm
The calipers I have are earlier 4 pot 65mm Tokico's.
Later, Doug
Reactions: Tusch and ROBBO
Super Moderator
So the caliper bolts are spread 65mm for the earlier and 90mm for the later generation?
Correct!
It may or may not matter for the wheel, rotors, or axle but will for the fender and calipers.
You'll need to do more research as I can't remember what all wheels fit what this time around.
Later, Doug
G
if its 90mm spacing nissin calipers you need as well as looking for bandit gsxr etc you could also look at the triumph badged nissins this is what i'm using on my 7r p model front end in my project, they are genrally cheaper on ebay etc but are the same caliper you just need to grind the triumph name off
I have some info on brake discs that fit the 7r wheels so if you need it shout up :)
Well the guy lied to me or didn't know himself. Thanks streetfighterkz because I never checked what I was told, live and learn I suppose. So I guess now the question is what's a decent set of 65 mm spread calipers. Do I still with stock 4 pot tokicos from the zx series or is there something recommended?
1 - 20 of 24 Posts
