1 - 6 of 6 Posts
YamahaHooligan
Discussion Starter #1
Well im getting the itch that's going around here for boost.
But I can barely rering pistons much less build a turbo setup.
So ive been thinking of adding a NOs duster to my fzr600..
Ive seen some fairly simple, inexspensive kits on ebay. Also read about a seemingly easy duster setup that just had to injectors in the air box directly over the carb inlets.
how much an I looking at for doing this right?
Is this even worth it?
Should I build up the engine components as well?
More than you think.
I'd go build a 660 first and see if you want more.
Definitely.
The FZR6's have a notoriously weak trans. It seems like once you start putting down over 100 WHP the transmission is a time bomb. For about the same cost as a nitrous setup, you could probably build a nice 660 and have the most power you can reliably get out of that bottom end.
Nope. All the ignition stuff stays over from the FZR. Mine was a little different since I used the YZF radiator, but I believe you can swap cooling systems between the motors. Worst case scenario you'll have to buy some radiator hose.
1 - 6 of 6 Posts
