1 - 8 of 8 Posts
Parts Pimp
My Bandit needs a new rear wheel and I have this busa wheel sitting here. I was thinking of swapping the bearings and coming up with shims/spacers fro the rest. Is there a good place for odd size bearings since the busa wheel takes larger bearings than the Bandit both in diam and axle size.
i cant fart
All balls bearings will have them but I usually try to use local shops when I'm buying bearings. Go on with measurements, come out with the right size bearings.
All balls makes decent quality stuff, and it's a fair bit cheaper than OEM.
Do a search for a local bearing distribuitor, chances are there's one around. There was one by me that I didn't even know existed for years, in a totally nondescript corner of a huge industrial building with a tiny little sign over the door. Any bearing you'll ever need, spacers, adapters, ect, ect.
G
Dont forget to change or sleeve the centre spacer in the wheel or those shiny new bearings will last all of about five minutes
1 - 8 of 8 Posts
