1 - 14 of 14 Posts
Here's a tip...
I was painting some bare metal I had after doing some welding to the bike. Well, of course, after the touch-up I noticed some spray paint had dripped down onto the front wheel fender. Shiny red fender + flat-black birdpoop drips = not cool. I tried scrubbing it with some Orange Blast cleaner to no avail.
So I looked around the garage for something that might be able to remove some dripped paint without damaging the fender's color.
DOT3 brake fluid. Yep, that'd work. TOO WELL. :D didn't use it.
Aaahh... WD-40. That cleaned my bathroom floor like a CHAMP. So I sprayed a little bit of it on the paint drips, and wouldn't ya know... Stuff came right off with a paper towel. Now the fender's as good as new, and you can't even tell I tried to use spray paint without properly protecting the surrounding area! Lesson learned.
Just thought somebody else might find themselves in a similar sitch, and now you know --- WD-40 will safely (more or less) remove over sprayed cheap rattlecan paint.
the mad doctor
i never thought of that. good info to have.
but uh... you seriously wd-40'd your bathroom floor?
make sure you've got your "help, i've fallen and i can't get up" button handy!
the mad doctor
The Green Lantern said:
wd-40 would work spray on,light on fire,problem taken care of :metal:
lol, that's how we used to clean spark plugs back in the day
Function IS Form
19 Z900, 88 Kat11
You can also spray things with WD-40 (or brush it on for cleanliness) that you fear might get oversprayed.
more ideas than money
only two tools you ever need.....
Duct Tape and WD-40
If it moves and its not supposed to..... Duct Tape
If is supposed to move and Dont........ WD-40
Duct Tape and WD-40
You forgot the hammer dude!
If it don't fit or still ain't moving.........it fucking will by the time i've finished with it.
Function IS Form
19 Z900, 88 Kat11
"All you need to work on anything is duct tape, WD-40, and a hammer.
If it moves and it ain't supposed to, use duct tape.
If it doesn't move and it's supposed to, use WD-40.
If it don't fit or it still ain't movin... it fuckin will by the time I'm done with it."
Yes.
1 - 14 of 14 Posts
