1 - 20 of 94 Posts
Super Moderator
This thread picks up where I left off after failing to complete the 2014 Winter Build-off.
I finally got all the pieces for my rearsets. I ordered a new lever plate and a M6 heim joint to complete my linkage as well as Zr7 shift link for the engine side. The Zr7 link was necessary as the GPz link was made to run the rod on top and with the Gilles running the rod on the bottom, I would have GP shifting which I don't really want at this time and the Zr7 linkage is underslung. So anyways, I installed the Zr7 link and wouldn't you know it, the side stand hits it.
It looked like I had enough room to cut and re-weld the joint inward.
But I don't..
So my options are GP shifting or relocate the stock sidestand or replace with something less bulky and cleaner.
Later, Doug
Reactions: Pariah
Chief Breakshit Engineer
Well I was just looking at this for my Gpz tonight
http://www.lowbrowcustoms.com/p1514...ick-stand-lug-mount-for-triumph-or-universal/
Cheapish and looks lighter than the stock one. My rough measurements tell me its a direct fit...kinda. The stock ones use en extra tab to stop the side of the kickstand whereas it looks like this relies on the throat of the clevis to provide the stop for the kick stand.
I was going to weld up a longer tubular steel kick stand in place of the cast hunk I currently have, why not put it in an out of the way spot
Super Moderator
Thanks for the link. I have a different kickstand and mount from a newer Kaw sportbike but I'm still debating on what I want to do. It's not like I can revert back to the stock rear suspension at this point anyway.
Later, Doug
Super Moderator
I messed with the side stand and linkage some more. I think even if I used a different linkage configuration the side stand would be in the way of the shifter and my size 13 foot.
I found a longer than needed shift rod in my spare parts bin and with a little help from a bandsaw, lathe, and die ended up with a correct rod.
Also finished the fender mounts using my cardboard template I did months ago. Again a little bandsaw, lathe, grinder, welder action..
The odd bolts will be replaced with some nicer looking ones when the time comes.
More to come as I get a little more time to work on it.
Later, Doug
Super Moderator
Haven't did a whole lot lately but progress is progress.
New steering stop tab welded under the stock one.
Got the exhaust off without any trouble. Four studs came out and the other four stayed in. No drama otherwise.
I also scored a Zr7 oil cooler from eBay for a pretty good deal. It's a little bigger but the fittings are the same just the hoses are a tad shorter. I still have to make new mounts as the GPz and Zr7 holes don't match up.
Also cut out the stock battery box brace and welded on a tab for rear M/C reservoir.
My "before final welding" to-do list is growing shorter.
Later, Doug
Super Moderator
A little more progress...
And the oil cooler temporarily hung from the new top mount.
Still need to make a couple bottom mounting tabs yet. Probably will get to them tomorrow.
Later, Doug
Super Moderator
Finished up the oil cooler lower bracket. I used the bracket I cut off that was made for the battery tray and cut it to be the same height as the bung used for the upper mount. My weld beads look like crap IMO but they'll blend in with the crap factory welds so no biggie.
Later, Doug
Super Moderator
Been a while but I picked up a really cool set of goodies on eBay that were so super cheap I just couldn't pass up.
Also built a battery box/cage/holder thing-a-ma-bob.
Tabs tacked up.
Plenty of room.
Mounted up a Zx10 R/R in the stock location with a simple bracket.
Later, Doug
Looking good, Doug.
I wish I was smart enough to buy some risers like those sweet LSL items you've got instead of buying generic-POS-butt fugly ones and messing up my top triple. A few helicoils and a lot of luck might just save it, or I'm gonna chalk it up as a learning experience and buy one of LSLs upper triples....hmmm Yantosh?
Super Moderator
A custom triple clamp would have been nice but the LSL setup was cheaper than just the postage of a Yantosh triple I'm guessing.
I'm now trying to decide on a decent set of bars. I have been using BikeMaster Superbike bars on all my projects but the risers sit a bit high so maybe dragbars are needed?
Later, Doug
Super Moderator
I was originally planning on using a Jardine GP-1 muffler from a Gsxr. It looks OK from the side but not great fitment. I will only have about 4.5" of ground clearance with it tight to the oil pan. Plus I will have to make a custom header as the MAC 4-1 that came with the bike ends way too far back to use it.
So I dug out a slightly shortened D&D I was going to throw on my Gsxr750. The MAC header went back on.
Too steep...
Little less steep...
Took a midpipe I had and used it to see what kind of room I had with the rearsets. I should have plenty. I will have to make a midpipe as the one I found is way too small to mate with the header.
Also started on a small fenderette thingy. Not sure if I'll stick with it or not.
Later, Doug
Reactions: BlitzBop and F'dup
1 - 20 of 94 Posts
