Gsxr 1000 triple tree help
1665 Views 4 Replies 3 Participants Last post by  Gsxr187
I have a 07 gsxr 1000. Looking to put riser and dirtbike bars on.
Only thing I have found so far is the lsl kit which with the fat bar risers and bars is costing over $600.
Do you guys know of any other options?
I tried to modify the stock triple and that didn't turn out too good.
Please help
1 - 5 of 5 Posts
You could have a custom top tree made
:D
I was thinking that too but thought it would be a shit load of money to get a one off made.
You guys think the lrc yana shiki would work?
I just drilled stock triple tree and bolted on risers.Made blocks of aluminum to sit under triple so made the stock triple stronger.Have had it this way for 6 years and had no issues.Lot cheaper than a custom made triple.Hope this helps.
I did this on my 04 636 stunt bike and never had a problem.
The thing is with this triple its not flat on the inside. I might have to take to machinist and have him mill some material out of there.
Do you have any pics of how you did it? I'm not quite understanding what you mean about the aluminum blocks.
I would love to have a triple made like the ones for the gpr stabilizer on dirtbikes. I removed the ignition so don't need a keyhole anyways. I just don't want to spend an arm and a leg to get that done. I wish there was a dirtbike triple that would go right on.
I was just going to use the stock clip ons pushed forward but I messed up and got the acerbis cyclops headlight and it won't allow me to do that.
Also how did you mount your speedo? Are you still using the stock one?
I was going to use a koso db-01r but I don't feel like doing all the wiring then I will not be able to use the mode function which is important since I got a flashtune and have the a b and c modes setup for different things. Normal, kill mode, and kill mode with race fuel.
I really appreciate your help.
Also does anyone know if the madass headlight setup would work on this bike? I know you can make anything work but would it require a lot of modding? If so maybe I will just get 2 projector headlights and make brackets.
1 - 5 of 5 Posts
