1 - 9 of 9 Posts
Hi there i plan on putting a gsxr1100 engine (oil cooled) 1992 spec engine, in my 1996 600 bandit, i no the bottom mount is slightly different, well this is what i have been told, i was wondering if anybody has done it or knows if the engine will fit.
thanks milbourne
Gorilla...Hired Gorilla
Should slide right in.....the fuel tap may hit the valve cover but thats it....it'll be a bitch to adjust valves so do em in advanced...may have to drop motor when the time come again
the only reason i was curious is the 1200 bandit mounts are different to the 600 bandit, well the bottom one is... this is all the mods i plan on doing tell me what you think
GSXR1000 Front end (Forks, Yokes)
GSXR1000 Front Wheel
Radial Calipers
Renthal Bars/ Drag Bars
Polished Resivour Tops (bandit engravin)
Brake and Clutch Lever
GoodRidge Hoses
Wavy Disks Front and Back
Recon wheels, spray lacker polish rims!
Radiator Grill
Stainless Scorpion exhaust
Akrapovic Race Can
Custom Seat and Cover
Custom Z1000 Tail Piece
Rear Light Unit
Streetfighter Nose Cone
Frame... Same colour as rest of bike
Chrome Rocker Cover and Carbs
Painted Head and Barrels
Polished Alloy casing (inc. front sprocket)
GSXR1100 Engine Conversion
1200 BANDIT Dual Braced Swinging Arm Polished
1200 BANDIT Rear Wheel
Chain Guard/ Hugger
Rear Caliper
No rear Pegs
Billet Rear Sets
Jack up Kit
Custom Decal Kit
1200 BANDIT Ohlins Rear shock
Custom Clocks
Chain and Sprockets
Frame Inserts
Oil Breather Filter
Oil Feed Hose
Torsion Bar
Exhaust Hanger
StreetFighter Front Mudguard
Steering Damper
Stainless Bolts Throughout
Full Respray
Miscellanious
The colour is going to be a deep blood red, with a heavy gold metalic or metal flake. The body work, frame, head and barrells and spokes on wheels going to be this colour
the mad doctor
all the oil cooled suzuki's use the same mounts. so like already said, it should go right in, but it's TIGHT. getting the motor in the frame is one thing, getting everything else to fit around it is another though.
The frame on the 1200 bandit and 600 bandit are the same apart from the bottom is cradle on 1200 (off top of me head), hopefully it will fit if not have to go down to gsxr750 motor.
thanks guys, what u think to rest of project
Sent you a PM with a link of a site that might be more helpful
the mad doctor
katana john said:
WELCOME TO THE MADNESS
You might want to look at the RF 900 motor if the 11 is to big.
I think it was just a punched out 750....But I'v been wrong once before.
rf's are liquid cooled. dunno if you've ever tried to stuff a water pumper into and oil cooled frame, but it's not easy at all. that, and rf's have a downdraft head, which would make getting the carbs to clear everything a nightmare.
i know there's been a few 6/11's and 6/12's (oil cooled) built, but i've never seen one first hand, so i don't know exactly what it takes to make it all work.
1 - 9 of 9 Posts
