1 - 3 of 3 Posts
Hi all i got a gsxr750k 89 and just got a 1052 engine of fleabay when it got here i noticed the valve seats are badly scored and the oil pump has been taken out so what i want to do now is put the crank, rods, pistons, barrel in my 750 as far as i can workout its all pretty much a straight fit, I'm assuming that i will need to use the 1052 clutch as well.
Basically i've got a weeks holiday due to me and need to make sure i have everything i need and it will all fit as this is my daily ride, I also want to turbo it using a td04 but not to sure what my compression ratio will be?
Wouldn't it be easier to just redo the valves and pop the motor in the 750 frame?
Yes but one there's no fun in that and two when I got the engine it was listed as in full working order when I got it the valve seats on three of them are quite bad and the oil pump was missing who knows what else is wrong with it so I don't trust this engine expecaly the why I ride and it's only got 5 gears
1 - 3 of 3 Posts
