1 - 20 of 55 Posts
Function IS Form
19 Z900, 88 Kat11
This is how it was in January, 2007.
Mods:
Upper and lower fairings removed
Acerbis Cyclops headlight
Custom undertail
Function IS Form
19 Z900, 88 Kat11
Replaced brake and clutch levers with Pazzo shorties.
Customized Big Bike ram air covers.
Tail plastics removed.
Clear Alternatives 2003 R6 taillight installed.
Function IS Form
19 Z900, 88 Kat11
Discussion Starter · #4 · (Edited)
March 2007
Custom exhaust
Painted
Driving lights
Acerbis Cyclops gone
Acewell 2800-series gauge
Custom plate mount
Function IS Form
19 Z900, 88 Kat11
PIAA headlights installed
made bracket for Acewell
next up is a massive amount of wiring
haelo said:
Up next is ghostriding it into a wall.
GHOSTRIDER ROCKS :metal:
not happy with the acewell?
Function IS Form
19 Z900, 88 Kat11
The speedometer doesn't work right. The odometer and trip, therefore, also don't work right. The tach doesn't work right. The fuel gauge never reads below half despite the resistance ranges matching.
did you add an extra piece to the mount that's on the gauge? Is it molded into the house or can you take it off and reverse it? I wanted to get that gauge but I want to mount on the bars like that but lower and between the bars and the tank.
Function IS Form
19 Z900, 88 Kat11
Yeah. I used a small conduit clamp and bolted the stock gauge mount to the conduit clamp, which I clamped around the bars with rubber.
have you been able to get it working right? Now your making me nervous if your having all of those problems.
1 - 20 of 55 Posts
