1 - 20 of 24 Posts
· Member
Alright you guys can you help me go through my options if i wanta put bars on my cbr? I would like to just do flat bars not motocross ones , but that doesnt really matter. What i need help with is installing and finding risers? I know alot of guys do it and I think this is something essential for the DIY section
Thanks
Scotty
· Function IS Form
19 Z900, 88 Kat11
A lot of us make custom risers. Get risers from another bike, drill holes in your top triple clamp and bolt them on. You can also buy an LSL or similar handlebar kit and just make/use bars that do what you want.
· aka crash test
i personally wouldnt go through the trouble of welding some on just buy a set of tag ones of ebay they are cheap drill some holes and bolt em on what kinda cbr you got???
· Eff Tee Pee
i've considered welding mine.
i did just drill thru the tripple and mount the dirtbike risers there. but i was considering welding it as well. Never really had any problems from not welding it tho, might have actually saved me from bending/breaking my forks when i looped a wheelie tho.
i can post up a DIY for dirtbars sometime soon. i'll be drilling for a new setup!
oh and
WELCOME TO THE SITE BP!
· Member
Hey thanks alot man ! A walk threw with some pics of the Drilling would be great! I love this site, I usually go on it during class and just look at ppls projects and thought it was finally time that i actually join it...
· Function IS Form
19 Z900, 88 Kat11
Welding is kind of a bad idea.
A weld is a lot more likely to break and leave you riding down the road with no handlebars than a drilled triple clamp is.
Welding is also a lot more work... If you have certain kinds of triple clamps, you can't drill them, but you'd be better off then modifying a triple clamp from another bike to work than welding risers on.
I have a cbr 954 and did a LSL bar kit on it. I priced it out for the kit at my local shop and it was pretty pricey but I was lucky and found the kit on eBay for a fraction of the cost used. The LSL kit comes with everything you'll need like bars, a custom upper triple tree with risers, extended SS braided brake lines, extended clutch cable, and mine actually came with extended throttle cables too. I paid $130 for the kit plus shipping but it was well worth it. Check out
http://www.spieglerusa.com/cfm/sbk.cfm
The kit is made by spiegler and you can navigate through the site to find a local dealer that can order it for you. But honestly you should keep a close eye on eBay and save yourself a good amount of coin!
-Rick
· fighter transplant in NC
some top tripples would be fine to weld on the risers. but not so much on the older bikes (ie yours and mine) its not such a good idea. the tripples were cast. and it was generally what is known as a large grain casting. basically a couple steps up from pot metal. although it can be welded by a good welder, the tension caused by the heat of the weld can caused some serious problems. namely weakening of the casting, cracking, warping, and stress fractures.
I saw a picture and read an article on a site where the builder used 1/8 steel cut on a band saw to match the center section of the tripple tree. Drilled through the steel the cast tree and made some of what looked like 1/2" thick washeresk pieces to fit in the casted base and it was concelled and the guy weighed like 250LB's and was doing high chairs on it without it breaking!
· DIZZLE
Have any pics or links?
· avatar gangsta
-Rick
OUCH...says mine is $320 !!! I am guessing you didn't get yours right from Spiegler, right?
For $320, I can get a whole new front end I can screw up completely, the do it all over again!
· Function IS Form
19 Z900, 88 Kat11
LSL kits are the top of the line when it comes to price, finish, and quality in handlebar kits. I bought mine because I like the Superbike bars and the Hayabusa's top triple can't be drilled.. I'd have to fit another bike's triple and drill it or buy enough machine equipment to make a tophalf.
i've wrecked :angry: with my drilled clamps and it held up just fine :yeeha:...can't say much for my bars, snapped my renthal twinwalls :mad: im about to re-cut my spacers and have them welded on so i can fit a damper :rock:
I guess I wasn't thining the other day when I went to the local shop and ordered my risers and bars. I am running a set of black renthal's, and a set of raised risers. Is the spacer block a neccesity?? Or can I change the placement of the bars?? Help...
1 - 20 of 24 Posts
