1 - 4 of 4 Posts
Winter's comin... :(
I ordered a 'Busa kit from AllBalls about a year ago and when it came in, never thought to check it, just threw it on the shelf..
I get around to checking it out yesterday and installed the lower in my GS450's neck, go to install the upper, and find out the bastards sent me two lower bearings.
Soooooo I need a Hayabusa upper bearing. Don't care if it's used, long as it's in good shape, and as close to free as possible. I can't afford to order a new bearing right now.
All Balls lists the upper stem bearing as 30x47x12... That's what I expected to get in the stem kit.
And no, you don't need a $45 custom bearing. I've done the swap like 5 times now, all you need is a 2-3mm spacer and that bearing size I just listed.
This is, however, the first time I tried to get the bearing set from AllBalls instead of ordering both bearings separately.
Haha... Shit. I'm an idiot. The busa does use the same sizes, I was reading the swap chart wrong on AllBalls. Well fuck me, then.
So I still need a 30x47x12... anyone got one?
1 - 4 of 4 Posts
