1 - 2 of 2 Posts
Got one of those cheaper street fighter lights. The bulbs have 2 wires coming off the back, and the stock kawasaki harness is a 3 prong. Im sure 3 instead of 2 for hi/low?
How to wire these cheap lights to the stock harness without cutting anything up?
If the lights suck, can i just epoxy in the old h7 bulbs into the light?
the built in LED turn signal lights really arnt bad and are pretty bright at night.
Just Here For The Party
The new headlight you bought is probably wired up for just on/off. If you want to use it, you'll need to splice into either the high or low beam lead and the ground from your harness.
You can swap in your h7 but I'd be careful about melting and setting fire to your headlight housing.
Post some pics of everything and forum members can give better advice. Welcome and make sure to introduce yourself in the new members section!
1 - 2 of 2 Posts
