1 - 11 of 11 Posts
The Hell You Say!!
It could be done but wouldn't be as stable and would be less resistant to lateral movement. There a lot of guys here that use stacked projectors and mount them to both fork legs.
If the lights are small then they are light and won't catch much wind, which will help with stability issues. I don't see any reason it won't work if you use sturdy enough material.
I think you got a real good idea here. I'm not a big fan of a couple tiny headlights perched between a wide, beefy set of forks. Always looks out of proportion to me. But hidden against a fork leg like this sounds awesome. If you decide to do it post a follow up here. I'd love to see it.
G
Its been done a few times over her in the uk most use a bracket from where the brakeline splitter mounts across to the bottom of the lights to provide some lateral support but i have seen a small triangle brakcet welded to the top yoke & bolted to the top light doing the same job
The one i saw using the second method also had the speedo mounted off this triangle bracket & both lights were joined together making a tidy job
Metal Slime
Yeah I think it would need some extra support now that I think about it more. A little head shake from a gnarly wheelie and it could get all Dennis Rodman. Then I'd have to straighten it out at the next stop light.
1 - 11 of 11 Posts
