1 - 10 of 10 Posts
ZUK ATTaCK
I ordered a custom length front SS brake line for my 2001 gsx-r600 and I just wanted to give a big thumbs up to that business.
I ordered the line monday afternoon, they made it that evening, shipped it the next day and I received it wednesday. The part is quality, including a double banjo bolt, single, and 5 copper washers.
It is 49.00 shipped per line, regardless of stock or custom length.
Even the packaging is great, you know all that wal-mart electronics that you have to cut the plastic open to get to it, its like that except it opens.
I just had a really good experience with this company.
Nate
Senior Member
similar price on galfers for custom lines, I've put them on more bikes than I can count. good stuff.
Recent Transplant
I'm looking at HEL for ordering new front lines for the CBR. My current setup has 1 main line from the reservoir, a T-junction with a rigid crossover above the fender, and then 2 shorter lines down to the calipers.
Does that mean I have to order 3 separate lines? or can I just replace the long one that goes to the reservoir? Does HEL include a t-junction and replace the rigid line with a braided stainless, or do I have to reuse the existing crossover?
Ammadien, you said you ordered just the one line for the front? How are your brakes set up? I can't see any way around replacing everything and paying 3 times as much for mine.
Recent Transplant
Good call, sev. Gotta go back and measure lengths for both lines now.
So just to reiterate, I need 2 lines with caliper fittings on one end, and a double banjo fitting on the other, the double banjo itself, and all the washers and stuff that go with it? I will have to contact them for a special order. Cheers!
Wannabe
Nope, you need two full length lines with standard fittings on both ends. A double banjo bolt, and 8 crush washers. 4 for where they attach to calipers then at the top where it attaches to the master cylinder you want to go along the length of the bolt like this:
bolthead|washer|brakeline|washer|washer|brakeline|washer|mastercylinder
Make sure to get a little extra length just in case you didn't measure quite right.
All star !!!
You have a link where you ordered from?
These are SS lines, right?
I also have a 2001 Gix project and I am gonna need brake lines sooner or later. :D
Frosty Rider
I wish i'd asked....I just bought 3 lines and all the fittings to replace the factory lines. It works, but two lines and no 3-way woulda been cheaper.
1 - 10 of 10 Posts
