I changed the plugs I think it's something with the headlight wiring harness I had to uninstall the coil packs and before I knew they had to be grounded I reattached them to the frame and grounded them still no spark coil packs bad?I think you break some wire If everything okay there. If the bike cranks over without signs of starting at all then you might have an electrical problem with your ignition system. I would check the coils on the spark plugs and the spark plugs themselves.
Didn't it happen that some wiring has internal creases? This may be the reason for the lack of current.I changed the plugs I think it's something with the headlight wiring harness I had to uninstall the coil packs and before I knew they had to be grounded I reattached them to the frame and grounded them still no spark coil packs bad?
