Hi folks,
Just wanted to post here to see if I can get a bit of help as well as just collecting my info together to try and sort this out & get it all straight in my head...
What I'm planning is to run LED lights direct from the stator (no battery, it's not actually a streetfighter, but a KTM 380 EXC supermoto that I'm building. I figure the lighting theory would be relevant to other bikes as well and you could just as easily run it from a bike that uses a battery - so hopefully this can be informative for anyone else thinking of building their own headlight from scratch). Here's the basics, I just need to fill in the bits in the middle:
Power Source: 12V, 130W
LED: CREE XP-G2 (3-up on star PCB), planning to use 2 of these in series
I've been trying to find which driver to use. Ideally I'd like to have one driver for both LEDs to keep the install nice & minimal and parts/weight to a minimum. But driving two of these in series means that the Vf increases to 16.8V. The only driver I've seen so far that could handle this is a FlexBlock boost driver, but the max output is 700mA. I'd like to be able to drive the LEDs at something closer to their max, for whenever I need hi beam. (Not that I'm ever likely to need to use hi beam continuously, but I'll be using a heatsink anyway so I'm not worried about heat damage etc.)
I found that FlexBlock driver on LEDsupply.com via their driver calculator.
I also found some much cheaper, basic drivers on LEDsales.com.au. These are only $3 each compared to $18 for the FlexBlock driver, so it almost makes sense to use one driver for each LED: Bare switchmode LED driver for one 1W LED
First thing that confused me was the description for that switchmode driver. It says it will drive a 1-watt LED at 350mA. So a 1W LED is one that has a max drive of 1,000mA? Is that correct? But then why only drive it at 350mA...? If someone can help me figure that out I'd really appreciate it.... :help0:
Regardless of which driver I use and what power I drive the LED at, I still need to figure out how to run a hi/low beam... From what I've been able to learn so far, to do it properly i would really need another driver on the low circuit lets say? Or I guess I could wire in resistors after the driver to drop the current for the low beam... placing the resistor after the driver - would that still result in a fairly constant current? The current into the resistor would be constant, so current out should be... but I'm not at all an electrically-minded person.
Another option is a dimmable driver, and wire it up so that the hi/low light switch just dims to preset values? But those drivers are $20, and only 700mA and that's the only suitable one I've found so far.
Thanks for any help that folks can offer on this. I will probably have more questions, but need to get these couple of things straight in my mind before I start thinking about other stuff.
Stats for individual LED
8.4Vf (typical forward voltage at 350mA)
1500mA maximum drive
