1 - 12 of 12 Posts
· Newbie
i installed an acerbis blitz headlight. after about 5 minutes or so it starts to smoke and i can smell burning plastic. i've seen plenty of bikes on this site with the same headlight. does the blitz headlight need to be modified to put on a streetbike? thanks.
· Eff Tee Pee
its not that complicated, i would take a look at the wiring diagram, you may have the hi/low wires crossed???
do you have your switch set on HI beams??
· (cheers smiley goes here)
My cyclops melted my throttle cable ?? There are little silver discs that go around the bulb, and they get hot as hell and the protective rubber boot slides off easy and doesn't protect shit ?
· Naked from the waste down
There's no difference between hi/low wires, 12v is 12v.
It's the bulbs hi element that burns brighter then a low element.
Here's my guess, did you buy the light new? Did you change the bulbs with a hotter bulb? Mine came with 35W lamps. They sucked for light but they're cooler then a 55w.
Take it off and see where it's burning. You can take that whole assembly apart with a few screws. Check it out and report back. Maybe take a few pics.
1 - 12 of 12 Posts
