1 - 7 of 7 Posts
is not your fucking bro
please please help me out. i need to know the outside diameter of a gsxr or busa rear wheel bearing hopefully, the cush and the wheel itself. i need to know for my bandit gsxr 1000 swinger swap
The Soft Serve Enigma
Rear wheel bearing on a 'busa is a 63022RS which is 58mm OD. Wheel itself is 17". Cush, I don't know...
(Diameter of wheel WITH a new tire (190/50-17) will be approximately 21 inches)
In the All Balls/NTN/Koyo bearings catalogue under my desk...and the diameter with tire, I did the math. It's actually closer to 20.7402", but I figured 21" was a good round number.
Full spec on the bearing is 32x58x13mm. 32mm THICK x 58mm OD x 13mm ID
thats a Parts Unlimited bearing # 6032
A bearing number is a bearing number. Whether you get it from Parts Unlimited, Tucker Rocky, or anywhere else. It's a standardized thing. You can go into any shop and say "I need a 'busa rear wheel bearing" and they'll order a 6032-2RS (2 Races Sealed) from wherever they can get it.
Function IS Form
19 Z900, 88 Kat11
You could go to a u-haul with that part number and get it probably :p
Well maybe not a u-haul but you get the drift :D
1 - 7 of 7 Posts
