1 - 4 of 4 Posts
I have HID projector out of a new body style Nissan Maxima. Sadly it is not a bi-xenon. The cut off shield is removable which means that you can make this headlight project exactly the way you want. You could remove everything and it could be used as a high beam, or shape it to get more light as a low beam. Depending on what you plan to do with it, it has great mounting holes on it all ready.
Included is the OEM Nissan ballast from the same car. Not chinese crap that will have the light flickering in two months of use. It is nice and small so fitting it into a motorcycle isnt bad, comes with the wiring plug with leads. All you need to do is hook up power and ground. I also have a bulb that is not pictured that I will send along also.
Asking $100. Let me know if anyone has any questions.
1 - 4 of 4 Posts
