I'm leaning toward putting them back on.
Hope you'll share the info/build of it. I've been considering making my own, but not sure what has changed since the A123 battery days.Hey my new battery came in!![]()
I kinda like em off. Depends on the look you're going for or if they actually function to cool anything.I'm leaning toward putting them back on.
Absolutely. I was trying to print the case for them now but my FEP is messed up and not letting me print properly. These things are 26650 LiFePo4 cells...3.2v/3800mah. Charging voltage running four in series is going to be about 14.6vdc so should be compatible with most rectifier/regulators and the cranking amps should be around 90a. This is what Antigravity's four cell batteries are made of.Hope you'll share the info/build of it. I've been considering making my own, but not sure what has changed since the A123 battery days.
Good suggestionAnother way would be to terminate the exhaust tips end on the same vertical plane.
Looking good, already!
