Greetings Ladies and Gentlemen:
The time is at hand to start my GSXR7/11 build. I plan on doing this build in 3 sections. Section 1 is build a roller frame using parts I can find relatively cheap. Section 2 is building the engine, probably with a lot of help from skr00z, since the engine is currently in 4-5 boxes and dozens of pieces. Section 3 is putting it all together and adding finesse where necessary.
I recently found a '01 GSXR750 front end for a "decent" price ($250). It comes with everything except the front wheel and clip-ons/controls. The question at hand is what work is necessary to get the '94 frame to hook up to the '01 front end. I've done some research with regard to neck bearing sizes and what-not, but haven't found a straight up how-to.
Thank you in advance for your suggestions and help.
Edit:
I also have a set of '02-'04 GSXR1000 forks, '01-'02 GSXR1000 triples, and a set of '04-'05 GSXR1000 brake calipers on the way. Am I better off piecing together the GSXR1000 front end, or stick with the GSXR750?
Edit:
