1 - 20 of 190 Posts
Major Slacker
I know people on here have set it up but for some of us electrically retarded people like me simple things can turn into nightmares. If any of you electrical gurus would like to throw up how you set it up I would be forever thankful.
I love lamps
get a dei solid state relay (SSR)
get a 12v rfid unit from ebay
remove your ignition cylinder and wire it through the SSR
if your bike doesn't have an ignition/accessories relay you can get a high amperage relay and wire your ignition through the relay, and the relay to the SSR
if you read up on how a relay works you'll be able to figure it out. People tend to overcomplicate electrical systems and get freaked out because they can't see what's happening.
Reactions: JoeGibs
I love lamps
the DEI latching relay is the "611T"
also, that's the down and dirty way to do it. there are a million ways to skin a cat though.
Never Enough
Taiden is right but the problem with a write up is that the wiring to replace the ignition is specific for every bike depending on what type of anti theft and how the ignition is wired in the first place. None are hard to do but each one is different.
Major Slacker
How about what wires go to the ground, to the battery, to the transponder or will the 611T and the RFID come with instructions on what goes where?
I love lamps
ground wires go to ground
12v wires go to 12v
I probably sound like a cheeky bastard, but I'm dead serious.
I'm still dead serious when I say people make electricity more complicated than it needs to be.
99% of electronics you buy have a data sheet that tells you what every wire does.
The only electrical items I have ever bought that didn't have data sheets or pinouts was solder, resistors, and wire.
Oh yeah, and heat shrink and electrical tape.
Buell Fighter
If I'm not mistaken me and Taiden have a pretty good thread already on this. Like he said, this shit is easy...it's the same as connect the dots. Hardest thing about it is making sure it looks clean and mounting it somewhere out of the way.
I love lamps
Major Slacker
I have read that thread a million times. It really doesn't say anything different than this thread does regarding installation. I see that people keep saying they are going to make a write up but still no write up.
I bought the transponder and the 611T this morning so we will see how difficult it is for someone with my limited knowledge. Should be exciting!
I love lamps
That's the way to do it. Give it a shot and if you get stuck ask questions and I'll do what I can to help. If you were local I'd make you a sandwich.
I love lamps
Yeah, if you paypal me $10 I'll send you a killer sandwich.
Reactions: Fizzer_Fighter
Im going to second a post from above. Im not a electrical guy, but I figured it out. Just buy the stuff and it will make sense when its in front of you. You need the RFID box and to wire up a latching relay(or use a solid state latching relay). I got all my stuff off ebay and spent less than 50 bucks for everything. I still have 3 RFID boxes left over. Ill use one on my CB750 project.
That guy
Im planning on doing this soon,
I have to ask thought 3" of range between receiver and the key fob doesnt seem like much.
What I was hoping was mounting the receiver under the seat, and keeping the keyfob in my wallet.
And to be honest a full how to along with pics would be a big help here.
While electronics are in fact relatively stupid (its all ment to transfer energey, or stop the flow of enegery essentially) I have not delved into RFID ANYTHING.
So I nominate BLUEJEWBALLS to complete the how to, with pics. He's apparently got the hardware coming, so it would be perfect for him to do it.
Please
Buell Fighter
Please
3" is enough if you use a latching relay. That's the key to using the rfid fob as a swipe. If you are planning on doing the system without a latching relay you have to leave the fob within 3"...and that sucks.
Major Slacker
Please
Ill tell you what. If by some miracle I get this thing to work ill see if I can write something up. Dont get your hopes up though. It also might take a while since the stuff hasn't even shipped yet + its a holiday + im lazy as hell
1 - 20 of 190 Posts
