1 - 7 of 7 Posts
Ebay PosterChild
How to make brake lines
When cutting the braided line to length wrap half a dozen turns of insulating tape around the hose and cut through the tape, it helps to stop it fraying out. ALWAYS cut the line with a hacksaw, if you use cutters you will introduce two weak points in the brake line at either end of the hose and the hose will possibly rupture under heavy braking. Clamp the hose just tight enough to hold the hose so the inner isn't crushed.
http://www.disturbingthepeace.co.uk/webpics/sickpup/1.jpg
The end of the hose once cut will look like this. You can clearly see the inner PTFE hose and the outer braid. You can clean up the inside lip of the hose with a small scalpel.
http://www.disturbingthepeace.co.uk/webpics/sickpup/2.jpg
Next slip the nut end of the banjo onto the hose and then fit the sealing olive. The sealing olive works just the same as the olive in a central heating joint, it deforms to fill gaps. The olive is fitted between the outer braid and inner hose and pushed into place. The easiest way is to push the hose against a solid flat lump of metal, in this case the edge of a bench.
http://www.disturbingthepeace.co.uk/webpics/sickpup/3.jpg
It's obvious when the olive is in place, look into the end of the olive and make sure the PTFE hose goes all the way up the olive as shown here.
http://www.disturbingthepeace.co.uk/webpics/sickpup/4.jpg
Next we fit the banjo to the hose. The banjo has a sticky out nipple that fits inside the PTFE hose.
http://www.disturbingthepeace.co.uk/webpics/sickpup/5.jpg
Pull the banjo nut up the hose to the banjo and tighten. when fully tightened there will only be one or two threads showing.
http://www.disturbingthepeace.co.uk/webpics/sickpup/6.jpg
Do the same at the other end and you have your complete brake hose.
Advanced Class
To protect your brake line and to stop sacrificial corrosion where the line touches fork legs or yokes the line is often covered with heat shrink tubing. To do this do as follows.
Always fit heat shrink in two parts. Fit the heat shrink after fitting one of the banjo's. The first part should go from one fitted banjo to no closer than 1 inch from the other end of the hose...
http://www.disturbingthepeace.co.uk/webpics/sickpup/7.jpg
...and shrink with a heat gun.
http://www.disturbingthepeace.co.uk/webpics/sickpup/8.jpg
Then add the second bit of heat shrink and add the nut for the second banjo. As you can see the banjo nut doesn't fit over the heat shrink, this is why you fit it in two parts.
http://www.disturbingthepeace.co.uk/webpics/sickpup/9.jpg
Fit the second banjo as detailed above then shrink your second piece of heat shrink and your line is finished.
http://www.disturbingthepeace.co.uk/webpics/sickpup/10.jpg
Ebay PosterChild
you can also use a zipcut wheel to cut the line so it won't fray so bad and goodgidge and russel both had diy kits which i am curently trying to find on their sites
junkfighter
you have to register to the forum, but the article is here:
http://www.disturbingthepeace.co.uk/vb/showthread.php?t=9680&highlight="Brake+lines"
Its infomative if you already have the parts on hand, but doesn't give you any links on where to buy the hose, fittings, and banjo bolts...
Looks like these guys will custom make lines for you:
http://www.paragonperformance.com/Dotbrk.html
and Drag Specialties has some stuff. not the same adapters as the above guy, tho. You can only buy lines in one inch increments that already have the ends assembled...
http://www.dragspecialties.com/fatbook/3/64/3908324?q=banjo fitting
1 - 7 of 7 Posts
