Yes I put it into dealer mode and no codes tps is good. I unhooked the battery for a bit will I was looking at everything. Will the battery being disconnected reset the ecu. Also it is running fine its only when I get aggressive on the throttle that I have this stuttering problem, this only started after I replaced the rotor and stator. If Im just cruising its fine but thats not too often. I like to ride fast!
