Bike wouldn't turn over. Pull plugs to check for spark, after making sure fuel was good. 2 cylinders no spark, both coming from same coil.
Replaced said coil. Still no spark. Pulled wires from good coil, hooked up to new one, got spark. So coil is good, wires connected well, spark plug good. Checked ground side by using the good signal wire and existing ground, spark. The only wire that I cannot get to work is the signal coming from the ignitor to the coil. Everything else works off the unit but this one connection. How likely is it that my ignitor needs to be replaced. I don't want to order if I don't need because they are pretty expensive even used on EBay.
