161 - 175 of 175 Posts
Wanna be racer
Discussion Starter · #164 ·
Had a couple of productive days,
Got a new seat
Mounted up the rear end
Figured out my m unit issue... who knew you needed an ignition.. bollocks
All lights wired up and working.
Cdi almost wired up just need to sort out the pickups from the engine and power
And finally the race technology dash 2 has lit up for the first time ever
Wanna be racer
Discussion Starter · #168 ·
We're getting there, but we're not out of the woods yet.
Finished off the wiring for the fuel pump, as it runs from the pulse signal for one of the coils. Fitted a pull choke from a cb1300 since I changed the switchgears it didn't have one anymore.
Next job will be sorting out the dash, then tidying up the loom cutting wires to length and then fitting the coil wrap
Wanna be racer
Discussion Starter · #173 ·
To do list;
Check front end spacers
Wire up clocks
Tidy up and wrap existing wiring
Throttle cables
Lockstops
Clutch fluid reservoir mount
Hoses for the oil cooler
Coolant expansion bottle
Spring clips for fuel hoses
Longer side stand
Rear caliper/hose/master cylinder
Seat lock mount key delete
Rear axle spacers
Rear wheel milled and chain alignment
