1 - 3 of 3 Posts
Just Pissing in the wind.
ok so ive used the search function and searched all damn day on the interwebs. heres my situation. i thought i had the right kit but now im secconed guessing. i have a GSX650F the same motor that was in the earlier bandits. i have a straight pipe and pod filters. can some one give me some advice? im thinking a stage 3 kit which i have will be fine.
ShamanFighter
depends on your current jetting and how much bigger the main jets are in the kit also
how you have your pilots set.
best thing to do is start with a plug reading. check your plugs
are they white? are they coffee and cream in colour? are they sooty and black?
you want a good coffee and cream colour.
then I would set up a time at your local Speed shop to get a Dyno Base reading and go from there.
it will show you not only your Hp and your Torque and Penis Size but MORE importantly your Air Fuel Mixture. you want a Good mixture to have a happy bike.
On my bike (bandit 1200) i had a jet kit an advance kit a modified air box and an almost strait outlet.... Ran Spot on perfect for my area...
now i have no exit pipe and 3 inches of conduit and its loud as hell and it pops like crazy so i need to jet accordingly.
Reactions: StaticLowLife
Repped thank you for the advice sir! i will have to check the plugs tonight
1 - 3 of 3 Posts
