1 - 4 of 4 Posts
CAPTAIN AWESOME®
Enter here for July 2016 FOTM, same rules as always.
minimum of 50 posts
4-8 good pics of your bike (and tell us which one you want used for judging)
list of mods and such
must currently own said bike
past entries allowed providing
1. you did not win
OR
2. you've made measurable upgrades since last time
deadline is the 21st before we start voting
Entry posts only. All others will be taken out back and have their toenails removed
+ this month if ROBBO enters his bike will win ! Roolz OK !
fook it I may aswell? first pic for judging photo please :)
sorry about the speedo cable being disconned in this photo!
frame:
1996 cbr600 f3 engine and frame
Home-Made welded in subframe
ForStunt Crash Cage
rider controls:
easy-pull stunt clutch perch
shorty levers
drag bars
modified top yoke to accept risers
electrics:
home-made electrics box
wave headlight
LED strip tail light
Koso Speedo
engine/carbs:
jetted carbs to suit Ram-air removal
'Clean air' mod to airbox
bodywork:
hydrodip 'skullz' bodywork
custom flat track style tail peice
home-made seat pad
ZX-6R Fighterer
Hoping this applies under rule 2 :LolLolLolLol:
It's all finished at this point only needs a little bit of touch ups, but I'm done turning wrenches on this one for awhile.
Kawasaki Ninja Z600R
Can you use the 1st pic for voting?
Mod List:
Front:
03 Z1000 headlight cut and shaped
Volar windscreen
Custom wiring
Stock cluster fitted
Orbital Racing grips
Chinese mirrors
Custom bar ends
09 ZX6R rear resi
Mad Scientist Moto levers
Core Moto blue brake lines
00 ZX12R triples - Top triple cut to fit ignition
00 ZX12R forks
02 ZX12R rotors
02 ZX6R wheel painted and polished
05 ZX6R front fender
Mid:
Frame painted gloss black
Ram air holes capped off with PVC caps
K&N Filters
98 ZX6R gas tank with Emgo cap
05 ZX6R coolant resi
Engine painted gloss black
Stainless steel engine cover bolts
03 ZX6R headers
13 GSXR 750 M4 muffler
05 ZX6R heel guards and footpegs
07 ZX6R rear resi
Core Moto line
Custom tail adapter plates
Rear
2013 ZX6R subframe
2013 ZX6R seat
2009 ZX6R tail fairings
Aftermarket seat cowl
Fender Eliminator
LED turn signals
Polished 05 ZX6R swingarm
05 ZX6R shock and linkages
Custom caliper bracket fitted
JT Sprockets 15/40 and 530 chain
Paint:
Dupicolor Ocean Blue metal speck
Dupicolor Wheelcast Blue
Gloss black paint
I think that's it. Been a journey building this thing. Best of luck to all contenders :rock:
Longtime rider
I started out with a Stock Bandit 1200. I am sure most of you"ll if not all .( Everyone should know anyway) I start out with out my Stock 03 Bandit 1200( The gray one ) and StreetFighter Which was a 03 Bandit 1200. Just to show a place where it started and where it is now.
Modifications:
GSX-R 750 Front end
DanMoto Rearsets
Bar end mirrors
Hayabusa rear shock
8" Ext sway arm
Keyless Ignition
Exhaust chop
Gauges is a GPS
Custom RPM Gauges ( with the skully inside )
K&N Air Filters
LED turn signals
ZX10 Tail section ( With LED tail light and intergrated section )
Driving Lights With 100 watt bulbs
Clutch window
139Db Air horn
Custom Air brush paint ( Landmarks of Atlanta As well as CustomFighter logo )
Pop top Gas cap flush fit on tank
Frame and Forks Powder coated blue
And I am sure there are things I missed.
Use this Pic.
Clip on pic for video.
1 - 4 of 4 Posts
