1 - 5 of 5 Posts
Include 4-8 pics. Decent lighting and resolution.
List the mods and any info about the bike.
Note the pic you would like to be used for voting.
Include a name for the bike, if you want.
It must be your bike, and you must have at least 50 posts.
Voting goes up on the 21st, or as close as I can get to the 21st.
All non entry posts, and posts that do not meet the requirements will be deleted.
V4's FTW
After 5+ years of building in secret, I finally get to play!:party-smiley:
Pic#2 for voting please
1996 Honda VFR750F "Blue Meanie"
ENGINE – standard internals, soda blasted/primed/ceramic painted, de-snorkeled, K&N air filter, UNI crankcase breathers, GSXR stick coils on rear head, Two Brothers 4-2-1 full stainless header with modified CRF250F end can and custom link pipe, SebspeedCustoms (owner) windowed clutch cover, Factory Pro jet kit, modified and relocated oem oil cooler, full SAMCO hose kit, Core Moto ss clutch line, 1-off carbon rad covers, stainless fasteners
FRAME – 1996 VFR750F, bead blasted and painted gloss black, 1-off adapters to fit painted 2008 CBR1000RR subframe, SpeedKing rearsets on 1-off adapters with 1-off carbon heel guards, modified CRF450 rear master with VFR internals, Vortex frame sliders
REAR END – powdercoated stock swingarm, lightened rotor, DID Gold X-ring chain, +2 sprocket, Core Moto ss brake line and speed sensor cable run through arm, Wilbers 641 shock re-valved & re-sprung, 98 VFR80 rear wheel, eccentric flipped plus shock shimmed to correct rake & trail. 1-off parts: carbon chain guard, carbon hugger, brake torque arm, wheel plug, hub slider
BODYWORK – 08 CBR600RR front fender, 92 VFR750F gas tank modified to fit 96 frame, keyless gas cap, 08 CBR1000RR tail & solo cowl, seat pan modified to match tank & reupholstered by Travis Bowen, 1-off carbon side panels, knee pads, bump pad, carbon accent on solo cowl, cowl release, aluminum sheet undertray
ELECTRICS – heavily modified VFR loom. KTM headlight housed in 1-off aluminum housing and modified to fit digital hi/lo HID kit & LED running light, Shock racing led front signal, LED strip rear signals, KOSO DB-02R gauge w/ dash, MOTY 8-cell LiFePo battery, keyless RFID ignition, Powerlet socket in tail
PAINT – PPG Toyota Blue Ribbon Metallic by owner
FRONT END – 2007 CBR1000RR “NOHLINS” forks painted by owner using HOK Pagan Gold candy and Orion silver, re-valved, re-sprung, and internally lengthened by owner, RC51 SP2 wheel, CBR1000RR rotors and calipers, 1-off sliders, BFT lower triple, CB1000R upper triple, Driven Meteor Fatbar, VFR800 and RC51 switch controls, choke relocated to lower frame, HRC 1/5 turn throttle tube, early Fireblade grips, Brembo forged 19x18 brake master, Brembo billet 16x18 clutch master, ATE Typ200 fluid throughout
My build thread here: http://www.customfighters.com/forums/showthread.php?t=110041
Super Moderator
Bump for entries?
Well fook throw me in.
First pic for the voting.
Triumph Daytona 955i DSSA 2002
-Fairings removed of course, the single seat tail is made by Airtech Streamlining
-seat quick release modified from an indoor door latch mechanism
-Projector headlights with traditional halogen bulbs, modified parking bulb. Twin tail light self made (minus the actual lights)
-Front fender shortened
-Dirtbike handlebars, modified top triple & clamps, adjustable shorty levers, bar end mirrors, brake fluid reservoir, Wezmoto custom length steel brake lines
-Hands free keyless ignition, lock removed
-Koso RX-2 gauge
-About half of the wiring redone
-Seat re-upholstered
-Crash cage self fabricated with self made crash bungs (not in pics)
-Headers polished
-Samco sport blue silicone coolant hose kit modified from 04-> set, custom made stainless T-bit& permaquick type stainless hose clamps for a cleaner look
-Danmoto adjustable rearsets, modified to accomodate the original foldable footpegs instead of the ugly rigid stubs
-Danmoto JISU muffler with self made baffle & midpipe, ProJection components lasercut hanger
-Rear mudguard/plate holder self made
-4x Knife type LED indicators, digital relay
-Custom paintjob, orange stripes painted, graphics hydrodipped over silver basecoat and covered with three layers of candy blue clearcoat
-RK Gxw 530 blue superlink chain, -1/+2 JT steel sprockets
-Loobman chain oiler
-12v cigarette output socket near left rearset for navigator and heated jacket
-Hugger and chainguard hydrodipped in carbon fiber pattern
-Coolant expansion tank modified from a 1kg fire extinguisher
Really? This becoming another duel? Cmoon I'm sure you guys have ready bikes by now it's season and all...
fairy nuff, I'll stick my oar in, help make up the grid
long time since I finished a bike , but, I think, about 7yr after starting this one its now finished, running and insured , has survived an IOM TT trip and still starts every time
I started with this
and after much to do , ended up with this
build thread is here
http://www.customfighters.com/forums/showthread.php?t=55527
Spec sheet
ZXR750 front wheel and discs
modified ZXR spindle
Tockiko radial calipers
caliper spacers by me
K5 GSXR forks
pattern gsxr mudguard
yokes by me
headlight mounts by me
B12 headlight - powdercoated
B6 clocks retro fitted with Koso speedo
riser block by me
magura fatbars
renthal grips
bar ends by me
ducati radial master cylinders
sprint steering damper, owner made mounts
modified GSX1100ET tank with R1 filler neck
modified GSX1100EFE frame
gsxr side stand
Setrab 19 row oil cooler
nylon / aluminium lockstops by me
goodridge oil lines
1216 bandit / GSXR motor
engine mounts by me
billet pick up cover
modified clutch and pick up cover
aluminium breather tank
B12 carbs
aluminium airbox
foot controls from.....? can't remember
footpegs by me
GSXR 1000 shock
adjustable dogbones by owner
K5 GSXR swingarm , modified by owner
SRAD rear wheel
suzuki tail light
GSX tail plastic
seat by me
paint - black, by me
pinstripe by Lawrence Laidlaw
ally undertrays by me
wiring loom by English Neil
green dyna coils
B12 headers
link pipe by me
end can by me
suzuki rear caliper
stainless torque arm by me
number plate mount by me
ally clutch slave cylinder mount by me
and possibly oddles n doodles of other stuff
stuff not by me (just for clarity)
pinstriping
top end rebuild
1 - 5 of 5 Posts
